Sheradan Posted November 4, 2009 Posted November 4, 2009 What is the best way to do a twin antenna setup on a 1st gen? I have them both with extra mount. Should I run 1 antenna to the CB and eleminate the splitter, and the other directly to the stereo? Or go 2 into 1, then into the splitter?
utadventure Posted November 4, 2009 Posted November 4, 2009 The splitter is a challenge for the CB to function well. When I did mine, I ran an antenna to each the radio and the CB and eliminated it. It made matching the CB antenna to the CB much easier. Dave
saddlebum Posted November 5, 2009 Posted November 5, 2009 The splitter is only there to be able to run two devices off of one antenna . It is actually a compromise. A separate antenna for each (and get rid of the box ) is an improvement to say the least.
warthogcrewchief Posted November 5, 2009 Posted November 5, 2009 How would one remove the splitter and install two new anntenna wires? I've got everything apart right now for my rebuild as I do the body work, so it should be fairly easy as I begin to rebuild everything. Thanks, WHCC
