Smitty161 Posted June 11, 2009 Posted June 11, 2009 I could use you all to way in...I have my steering head apart and can not get the bottom bearing to unseat. It is sitting in a plastic cup. Like to know how much I can beat on this and still have usable parts when done. New parts are days away and I need to ride soon.....
Smitty161 Posted June 11, 2009 Author Posted June 11, 2009 So am I stuck with going to a shop to have taken off and pressed back on?
Squeeze Posted June 11, 2009 Posted June 11, 2009 Well, usually, whatever Route you go to dismount the Bearing, it's Trash after you got it off the Steering Stem. But why do you want it undone if you want it back in Place ? There's no Room for Error, this is an really important Part of the Chassis. When you're already in there, you better replace the Bearings and be done with it for Years. .... just my 0.02 US$
bongobobny Posted June 11, 2009 Posted June 11, 2009 Well, the guys in our machine repair shop clamped the bearing in the vice and pounded on the triple tree shaft. Your best bet is to replace the bearings and races for the small cost of the bearings. The bike will steer a lot smoother...
Smitty161 Posted June 11, 2009 Author Posted June 11, 2009 Thanks for waying in everybody. Job is just going to have to take longer. Bearings and races.....I know, Iknow.....do it right. Back to the parts counter and shop I go. Dang it! Even with the hassles....I love this bike!
Freebird Posted June 11, 2009 Posted June 11, 2009 I've repacked the front bearings a couple of times. If you were not having a problem with the bearing and just repacking it, do it in place. I usually drop the front far enough to get to it and repack it in place. Works fine and never had a problem.
Smitty161 Posted June 11, 2009 Author Posted June 11, 2009 Thanks Freebird. The bearings are in good shape, just dry. And I do want to ride. Feeling like my shoulders have a devil and an angel perched.
RedRocket Posted June 12, 2009 Posted June 12, 2009 I've repacked the front bearings a couple of times. If you were not having a problem with the bearing and just repacking it, do it in place. I usually drop the front far enough to get to it and repack it in place. Works fine and never had a problem. That's what I did. My lower was "almost dry", so I repacked it, and reused it. The top bearing was was beaten, seemingly by the heat. The remnants of grease were hard, and almost black.
Gearhead Posted June 12, 2009 Posted June 12, 2009 Examine the races really carefully. Do they have any lines in them that line up with the rollers? If so, they need replacement. If not, they may be OK. But as someone else wrote here recently, that's a lot of work to do, you might want to just do the new bearings at this point. I got the lower bearing off using a die grinder to get it thin and then a cold chisel and hammer to crack the thin spot. Jeremy
bongobobny Posted June 12, 2009 Posted June 12, 2009 We can send Big Tom and SpankyM over, they are experts now with a rotary cutter, chisel and hammer...
Smitty161 Posted June 12, 2009 Author Posted June 12, 2009 The name Big Tom sounds okay....but the name Spanky kind of worries me. If they come as a pair I think I'll pass.
