skydoc_17 Posted May 10, 2009 #1 Posted May 10, 2009 I recently purchased a First Gen. Parts Bike and was told by the owner he "thought" the final drive on this bike was from a VMAX. Does anyone know of a way I can tell if this is indeed a VMAX final drive? I have attached two pics below and the red arrow is pointing to what looks to be a mounting point for a rear shock. Could someone please help me?!?! Earl
Squidley Posted May 10, 2009 #2 Posted May 10, 2009 Earl, Thats not a giveaway as they used the same casing on many of that era Yamahas. The only was I know of is to look at the gears inside the pig. If the ring gear is a 9 tooth then it's a Vmax if it's a 10 tooth it's a Venture. If I'm wrong with that statement you will have answers quickly to dispute my statements
autopilot Posted May 10, 2009 #4 Posted May 10, 2009 (edited) If you're going to take the rear end off the parts bike anyway, and can find out the gear ratio for the Vmax, all you would have to do is be able to see the input shaft some kind of way. Rotate the tire one complete turn and count the number of revolutions you need to get one revolution on the input shaft. Once you have the ratio, you'll know which differential it is. Obviously you have to mark the wheel and the input somehow, so you can make an accurate count. Just a thought....if you didn't want to have to get into the differential. Edited May 10, 2009 by autopilot misc.
Squidley Posted May 10, 2009 #5 Posted May 10, 2009 autopilot said: Rotate the tire one complete turn and count the number of revolutions you need to get one revolution on the input shaft. Once you have the ratio, you'll know which differential it is. Obviously you have to mark the wheel and the input somehow, so you can make an accurate count. Yeah thats a good idea too, didn't think of that one
bongobobny Posted May 10, 2009 #6 Posted May 10, 2009 OK, not sure f the MK2's but I DO notice there are no "rib" on the casing, which may inicate it IS a VMAX..
CrazyHorse Posted May 11, 2009 #7 Posted May 11, 2009 I have a vmax rear end laying around and it has a shock mount on it. Where's Squeeze at when you need him?
Rocket Posted May 11, 2009 #8 Posted May 11, 2009 Jimbob5 said: I have a vmax rear end laying around and it has a shock mount on it. Where's Squeeze at when you need him? Probably playing with the new V max.......:thumbsup2:
Squeeze Posted May 11, 2009 #9 Posted May 11, 2009 Rocket said: Probably playing with the new V max.......:thumbsup2: Hey, I'm here !!!! Not really playing with the VMAX this Weekend. I was mounting a Aftermarket Fork Yokes on a Buddies Vmax on Saturday and visited a Friend yesterday to fix his Carb Problem on the Vmax. We took the Venture and had a fantastic Day with riding, Texas Steaks off the Grill and a wet Trip back Home and camein just before midnight ... Back on Topic ... If you turn the Shaft 9.9 Times to have three Turns on the Output Spline, it's a Venture Ratio, if you need to turn the Shaft eleven Times to have three Turns on the Output Spline, it's a Vmax Ratio.
Squidley Posted May 11, 2009 #11 Posted May 11, 2009 Squeeze said: If you turn the Shaft 9.9 Times to have three Turns on the Output Spline, it's a Venture Ratio, if you need to turn the Shaft eleven Times to have three Turns on the Output Spline, it's a Vmax Ratio. And there you have it! Lutz your pretty handy to have around here with us
Yammer Dan Posted May 11, 2009 #12 Posted May 11, 2009 Squidley said: And there you have it! Lutz your pretty handy to have around here with us Sure is. Helped me not long ago even if my plans fell thru. I'm still looking Squeeze. Only one I've found is 150 bucks so far. Shhh!!!
