PRAIRIECOOT Posted March 14, 2009 Share #1 Posted March 14, 2009 question to one and all will a 83 1200 venture motor swap into a 85 venture ???? thanx Merv Link to comment Share on other sites More sharing options...
Yammer Dan Posted March 14, 2009 Share #2 Posted March 14, 2009 Yep!! Link to comment Share on other sites More sharing options...
Dano Posted March 14, 2009 Share #3 Posted March 14, 2009 Yep. But I would do the thrust washer replacement while you had it out. Unless your positive it's been done already. Ask more questions if ya need to. Dan Link to comment Share on other sites More sharing options...
FROG MAN Posted March 14, 2009 Share #4 Posted March 14, 2009 what wrong with the 85 motor? Link to comment Share on other sites More sharing options...
PRAIRIECOOT Posted March 15, 2009 Author Share #5 Posted March 15, 2009 THE 85 MOTOR HAS 98 KM ON IT REAR 2 CYLINDERS RUN VERY BAD, AND AFTER A RUN IT CHANGES EVERY TIME LIKE READJUST THE SYNCING TO GET RUNNING HALF DECENT CARBS ARE DONE -MOTOR WAS 1 PLUS LITRES OVERFULL WHEN I GOT IT TOOK 6 OIL CHANGES @ 100 MILES TO GET OIL TO EVEN RESEMBLE CLEAN - 1ST OIL CHANGE I WROTE MY NAME IN THE BOTTOM OF CATCH PAIL.REALLY DID!!! BEST MYSELF AND A MECHANIC CAN FIGURE IS THE TIMING CHAIN IS WORN TO THE POINT IT IS JUMPING NOTCHES . IS EVERYTHING THIS WORN // THINK SO !!!! HAVE A CHANCE TO BUY A COMPLETE 83 (57 KM) FOR LESS THAN REPAIR BILL ON THE 85 MECHANIC AGREES THE REST OF BIKE IS VERY GOOD CONDITION AND IT MIGHT NOT BE BAD TO HAVE A PARTS BIKE ON HAND DO YOU THINK THIS MAKES SENSE ???? APPRECIATE YOUR THOTS - ANY AND ALL READERS ---PLEASE THANX MERV:thumbsup2: Link to comment Share on other sites More sharing options...
PRAIRIECOOT Posted March 15, 2009 Author Share #6 Posted March 15, 2009 ""Yep. But I would do the thrust washer replacement while you had it out. Unless your positive it's been done already. Ask more questions if ya need to."" OK - What thrust washers???? I have the 85 motor ready to drop out - just need to slide mount bolts out appreciate your suggestion thx Merv Link to comment Share on other sites More sharing options...
PRAIRIECOOT Posted March 15, 2009 Author Share #7 Posted March 15, 2009 if you mean 2nd gear - Yessss I plan on it Link to comment Share on other sites More sharing options...
Venturous Randy Posted March 15, 2009 Share #8 Posted March 15, 2009 What is the serial number on the 85? If it is above 1413, it should have the upgraded stuff in it. RandyA Link to comment Share on other sites More sharing options...
bongobobny Posted March 15, 2009 Share #9 Posted March 15, 2009 Man, sure is a shame that engine was that misused! 98K is just about broken in for these engines! Sounds like you have a good plan, man! Link to comment Share on other sites More sharing options...
greg_in_london Posted March 15, 2009 Share #10 Posted March 15, 2009 Are you sure you wouldn't be better off ridind the 83 and breaking the 85 ? Or is only the engine for sale ? Link to comment Share on other sites More sharing options...
PRAIRIECOOT Posted March 15, 2009 Author Share #11 Posted March 15, 2009 GREG-IN LONDON I have thot not of maybe riding the 83 they are sending pictures tomorrow - that will likely tell the tale they said that they had a 83 with gummed up carbs sitting - and as I have 2 complete sets of carbs------ I originally thot I would transplant motor and use my carbs etc, mostly cause I have added lights, new windshield, seat repaired etc to mine and painted it But as I think on it - I bet all the painted and new parts on mine would go on the 83 so hell yes , that might be a super idea thanx - amazing how the obvious escapes us sometimes ---like not seeing the forest for the trees thank you for the suggestion will post what i do see ---2 heads are better than one - lololol Merv Link to comment Share on other sites More sharing options...
friesman Posted March 15, 2009 Share #12 Posted March 15, 2009 if you need a hand with something let me know and I can make a quick drive out to Cupar to lend a hand. I think its a good idea to move the plastic if possible, it would be a lot easier. Your 85 trunk is different but I think it will fit if you use the trunk mounting rack from the 85 Brian Link to comment Share on other sites More sharing options...
PRAIRIECOOT Posted March 17, 2009 Author Share #13 Posted March 17, 2009 tHANX TO ALL THAT HAVE RESPONDED ONE LAST QUESTION I was contacted by someone that has a "LIKE-NEW" 1988 1300 engine and he states that it will bolt right into my 1985 It seems to me that I have heard that the 1300 engines CANNOT be bolted into a 1200 ( 1985) bike Will the 1300 fit ??????????? thanx again Guys Merv Link to comment Share on other sites More sharing options...
friesman Posted March 17, 2009 Share #14 Posted March 17, 2009 Hi Merv When I blew the trans out of my 85, Condor and several others suggested that the 1300 swap would prbably a better way to go as it didnt need the trans fixed for the 2nd gear issue. It was supposed to be a straight bolt in as far as I remember, but I am sure more will chime in to confirm or correct. Brian Link to comment Share on other sites More sharing options...
Squeeze Posted March 17, 2009 Share #15 Posted March 17, 2009 All 1300cc Engine's fit mechanically as Bolt on between the 1 Gen's. Even the Carbs are the same except '83, but the jetting of the Carbs is different. So it might be a good Idea to have the 1300 cc Carbs also. If you want to use a '90 - '93 Motor, you need to do something about the different Pickup Coils. Link to comment Share on other sites More sharing options...
PRAIRIECOOT Posted March 17, 2009 Author Share #16 Posted March 17, 2009 I like the idea of getting a 1300 and not worrying bout the 2nd gear problem you say the carbs are different jets - assume larger jets ?????? like can I just put different jets in the carbs from my 85 will jets from a 1300 fit in the 85 carbs ??????? I have done the cleaning of the carbs - so teardown of the carbs is not a problem thanks to all of you answering and making suggestions- It really helps me out thanx Merv Link to comment Share on other sites More sharing options...
Squeeze Posted March 17, 2009 Share #17 Posted March 17, 2009 Sure, if you have a Carb Set or all Jets at Hand, you can "just" change them. They interchange without a Problem. But you have to change most, if not all Jets, Air as well as Fuel Jets. Needle Jets(Emulsion Tubes), Jet Needles. Depends on what Years you have lying Side by Side on the Bench. Buying them all new might cost you an Arm and a Leg, if not more. Link to comment Share on other sites More sharing options...
