Guest eyehook Posted February 12, 2009 Share #1 Posted February 12, 2009 I am preparing to fix my slipping at high speed clutch.Can anyone tell me where to get the parts?(beside the stealer) Link to comment Share on other sites More sharing options...
GeorgeS Posted February 12, 2009 Share #2 Posted February 12, 2009 just replaceing the Springs might do it. Or just replace the pressure plate assembly with a Barnett Unit. Usually the Plates are not worn, it usually just weak springs. Aftermarket complete replacement clutch and pressure , is about the same cost as OEM parts. I guess it depends on how long you intend to keep the bike on the road, as to how much to spend. But if stock spring replacement will do the job, that s the cheapest fix. Link to comment Share on other sites More sharing options...
ChurchBuilder Posted February 15, 2009 Share #3 Posted February 15, 2009 I saw these on ebay http://cgi.ebay.com/ebaymotors/_Motorcycle-Parts-Accessories__83-85-Yamaha-XVZ12-Venture-EBC-Clutch-plates_W0QQitemZ350152060398QQadiZ2863QQadnZMotorcycleQ20PartsQ20Q26Q20AccessoriesQQcmdZViewItemQQptZMotorcycles_Parts_Accessories Link to comment Share on other sites More sharing options...
Squidley Posted February 15, 2009 Share #4 Posted February 15, 2009 PCW racing in Schenectady NY, John Ganey is the man to talk to http://www.pcwracing.net/ I have installed his clutch kit in a dozen or so 1st and 2nd gens, less than $100 and can be installed in about an hour on the 1st gens. I'll never use anyone else and his service is top notch Link to comment Share on other sites More sharing options...
6pak Posted February 15, 2009 Share #5 Posted February 15, 2009 What Squidley said. Link to comment Share on other sites More sharing options...
mother Posted February 15, 2009 Share #6 Posted February 15, 2009 i did the Barnett clutch and wow. picked it up from Buckeye. Link to comment Share on other sites More sharing options...
Guest Swifty Posted February 15, 2009 Share #7 Posted February 15, 2009 What Squidley said. Link to comment Share on other sites More sharing options...
Condor Posted February 15, 2009 Share #8 Posted February 15, 2009 I always have to toss this in once in a while. If your clutch is slipping in high gear when the engine gets warmed up, but is solid until then, it's your expansion hole in the master that's plugged up, and not allowing the hot expanded fluid to excape back into the reservoir. Or... your reservoir is too full. OK, now I'm good for another 4-5 months.... Link to comment Share on other sites More sharing options...
StuD Posted February 16, 2009 Share #9 Posted February 16, 2009 What type of oil do you use. MC oil, deasel, reg car oil??? may be slippage if car eng. oil. :canada: Link to comment Share on other sites More sharing options...
TxVenture Posted February 17, 2009 Share #10 Posted February 17, 2009 What Squidley said. Don H. Link to comment Share on other sites More sharing options...
Squidley Posted February 17, 2009 Share #11 Posted February 17, 2009 What type of oil do you use. MC oil, deasel, reg car oil??? may be slippage if car eng. oil. :canada: This is also a good thought, if you are using energy conserving oil it will cause the clutch to slip. Just wanted to throw that in as well, but if your bike has a decent amount of miles on it and your using the proper oil....go with PCW Link to comment Share on other sites More sharing options...
Dragonslayer Posted February 17, 2009 Share #12 Posted February 17, 2009 This is also a good thought, if you are using energy conserving oil it will cause the clutch to slip. Just wanted to throw that in as well, but if your bike has a decent amount of miles on it and your using the proper oil....go with PCW What about air in Hydralic clutch line from lever to clutch slave cylinder, can't that cause slippage at higher speeds. Link to comment Share on other sites More sharing options...
Squidley Posted February 17, 2009 Share #13 Posted February 17, 2009 What about air in Hydralic clutch line from lever to clutch slave cylinder, can't that cause slippage at higher speeds. It could Bob, but what he's describing is a text book weak spring. If there was air in the system he would feel it all through the shifting and clutching movments. Link to comment Share on other sites More sharing options...
Guest eyehook Posted March 27, 2009 Share #14 Posted March 27, 2009 I had posted my clutch was slipping and I want to thank everyone for their replies.Put a complete Barnett in and wow!!!what Squidley said.:225:Side note:Mobil 1 M4t V-twin oil in engine. Link to comment Share on other sites More sharing options...
Yammer Dan Posted March 27, 2009 Share #15 Posted March 27, 2009 I always have to toss this in once in a while. If your clutch is slipping in high gear when the engine gets warmed up, but is solid until then, it's your expansion hole in the master that's plugged up, and not allowing the hot expanded fluid to excape back into the reservoir. Or... your reservoir is too full. OK, now I'm good for another 4-5 months.... Yep, Yep that'll do it!! Springs also get weak on these things. Clutches themselves hardly ever wear out. Link to comment Share on other sites More sharing options...
GeorgeS Posted March 27, 2009 Share #16 Posted March 27, 2009 I had posted my clutch was slipping and I want to thank everyone for their replies.Put a complete Barnett in and wow!!!what Squidley said.:225:Side note:Mobil 1 M4t V-twin oil in engine. Yee, Shall , Never Slip Again !!!! Link to comment Share on other sites More sharing options...
