This stream auto-updates
  1. Today
  2. It was 74 Sunday and 78 Monday here in Omaha. I got the bike put back together and put 240 miles on Sunday and fought the wind, but still had a good time. Monday I put 35-40 miles on the bike on the way home from work (I live about 6 miles from work lol) and rode to work yesterday. Woke up to over an inch of snow on the ground this morning lol Ride Safe!
  3. Good morning to all. Yesterday, I was able to ride to and from work and it felt great! Temperature was in the mid 70's and it marked my first ride of the year. My RSV fired right away and she was ready to go. Ride safe everyone.
  4. M61A1MECH
    Test
    It is working here.
  5. Woody
    Test
    it's working boss 😁
  6. Freebird
    Test
    Just making sure it’s working
  7. Last week
  8. 80 degrees today so we got our chores done and took a ride, about 2 hours of back roads.
  9. Earlier
  10. Good evening to All! We are having rain and a very unstable weather pattern over the course of 10 days...but I see some 70 degree temps coming up.
  11. I 'think' he is saying that he just might buy a new ride.
  12. Are you saying you are done riding now?
  13. No more snow in our area, but winter might just put another round of snow next week and hopefully that would be it for the season. I am so ready for Spring and also thinking that time springs forward on March 8.
  14. Been blowing and plowing snow this last week! Also repairing units as things went south! Roads were clear for a few days then Bam snow again! -19cel this morning when I picked up son from work! Got oil and filter the other day now just have to change it!
  15. So looking through Mcmasters, they offer carbon steel and alloy steel rods. The alloy is about twice the strength of the carbon, the alloy is more expensive, which is not a problem, but the next question is will I be able to weld the alloy with a simple 6011 rod, ....final pass with a 7018? I don't know if alloy means a different type of weld than the farmer / junkyard welding I typically do for structural fab.
  16. So, I talked to a fella with a small shop who will repair it for $600. Not gonna do that. I'll try to talk to another fella tomorrow and if his price is similar I think I'll take Dawsons' advice and drop down from 1 1/8" to 7/8" and replace the rod and the nut. We'll see how it goes.
  17. I was thinking the same thing, but the cost of the rod / nut may cost as much as to have a threaded sleeve made up. Better yet would be to have the original part bored and a new threaded sleeve inserted and welded in place. There's a little machine shop nearby. I'll keep the assembly in my work van and stop by and see what they say. I'm guessing a couple hundred $$$...Still worth it for such a beast of a vise.
  18. Thinking outside the box here John. I googled 1-1/4 ACME rod and found places to get rods and coupling nuts. Maybe replace the original rod and weld in a coupling nut. Make both sides new instead of matching the old. Or drop down a size if needed and sleeve it.
  19. Yup, It's a big-un. That's why I grabbed it but the repair's looking like it may be a problem. I could take it to a machine shop that's capable of cutting an Acme thread, but the expected cost may be worth more than the vise. I'm still exploring options. Thanks for thinkin' of me. πŸ™‚
  20. yep that's a lot bigger than the one I have in my shed, I broke the mounting ears off of it but the screw is still good. but it's way to small for what you have.
  21. John do have some pictures of this project?
  22. Looking at what McMaster-Carr offers and poking around on some machinist websites I find , you are correct that 1/4" or 1" ACME are typically made with 4 threads per inch and 1 1/8" ACME are typically made with 5 threads per inch. I agree with Ronnie, search out a local machinist to verify what you have, It is possible the vice manufacturer made their own proprietary thread form, that is not really an uncommon practice. The other possibility is maybe it is not a true ACME thread form, could a Buttress thread or a square thread, they look similar to ACME and are similar in strength and would be suitable for the lead screw on a vice. Again a half decent machinist would be able to tell you.
  23. Got a good machine shop close by? With the industry here our local machine shop has worked with a lot of acme threaded stuff. Somebody like that might can help you.
  24. Weird one. I've a very heavy, very large old Columbia vise that I've come across. At OSU, one of their shops was throwing out this old Columbia vise because the threads on the ?nut? were stripped. I've found that they're ACME threads and as I measure the diameter of the rod I get 1 1/8" diameter and count 4 threads per inch. I can repair this by finding a coupling nut that will thread onto the rod, cut off the part that's stripped and weld a coupling nut in it's place. The problem is that I only find 1 1/4" or 1" nuts offered with the 4 threads per inch. 1 1/8" nuts are available in 5 threads per inch only. I wonder if this is actually a 1 1/4 rod that I'm looking at. I haven't taken a micrometer to it, but as it sits it clearly measures 1 1/8" and it sure looks like 4 TPI. I'm measuring at the end and the threads don't appear worn at this point on the rod. Should I expect this rod that measures 1 1/8" is sized small to accommodate the loose fit desired for a vise?
  25. Time is up for me sitting on this chair. Will be blowing snow and clearing sidewalks in a few minutes.
  26. Got the bike out last week and the bug out a couple days ago and now we are staying in the house in front of the fire place cause it's to cold outside.
  27. So we had some snow yesterday and into the overnight. It turns out, it was not as bad as the last one that was coupled with a long deep freeze. Just sitting here at the big desk then will tackle the snow and clear my driveway and sidewalk in a couple of hours. Have a great Monday!
  1. Load more activity
Γ—
Γ—
