This stream auto-updates
  1. Past hour
  2. Put over 600 miles over the weekend, more than half wearing the helmet, and it gets an A+. Comfortable, reasonably light weight, great visibility and just the right amount of noise reduction. If I had any reservations, it'd be about the chin strap. Comfortable, but takes some getting used to. All in all I have no complaints.
  3. Today
  4. @saddlebum yes it was nice with getting together at Timmies then going for ice cream afterwards! Should have paid more attention to the date as forgot it was long weekend! Also got to ride with 2 other Ventures on the way to Kitchener then I broke off to go to Princes Auto to do some shopping, Over $130 worth!! Looking forward to next one!
  5. Nice bike!
  6. Yesterday
  7. I had a nearly new set of Vance and Hines Torquer 450's on the Harley I traded. Since the new bike takes the same mufflers, I put the original mufflers back one the 22 before I traded it. Put the V&H's on the '25 this morning. Haven't ridden it yet but it sounds good.. IMG_0335.mov
  8. nice bike! i hope you get to enjoy it for many years to come!
  9. Enjoy it!!! Get some riding time with your son.
  10. Nice Don!
  11. So my 98 RSTD is running great...but...it has a tendency to quit or become very difficult to start once the engine and rad are heated. I have heard from another member with this era of RSTD the location of the ignition can be a problem due to excessive heat from the motor and rad. So my question is can the ignition be relocated and if so, is there anyplace on the forum or elsewhere to get the info. I've looked but so far nada, bupkus, squat, diddly, zero. Thanks in advance.
  12. Last week
  13. So the 2022 Road Glide Limited is gone. I had strongly been considering saying goodbye to my riding days for some time now. The Road Glide Limited was a great long range touring manchine but now that I've turned 70, it sure was feeling heavy on these. short rides around home. So it was time to let it go. So my riding days are over. But Nay Nay say I. Today I picked up a slightly lighter bike. It is still HEAVY but feels 300 pounds lighter than the limited due to having no tour pack and them lightening the fairing by about 20 lbs. One test ride was all it took and I was sold. It has three factory ride modes. Sport, Rain, and Highway. Plus another one that you can customize to your liking. The salesman told me that in sport mode, Harley has everything dialed up to about 80%. He created a custom mode for me where he set throttle response and everything to 100% and the performance was amazing. It is really too much unless you really want to play hard. I actually put it back into Sports mode and even highway mode on the way home. So what did I buy? A 2025 Harley Road Glide and I have to say I love this thing. It has the new 117 Cu In motor with 105 HP and 130 lbs of torque. It actually feels even stronger. All the modern goodies. ABS, Traction Control, etc. Apple car play, navigation, etc. 12" digital screen that you can customize to your liking. They upgraded the front and rear suspension and added an additional 3 1/2 " travel to the rear. I am just completely impressed with this bike. I got them, to throw in a passenger backrest and a taller "Klock Werks" windshield. Since taking these pictures, I added a riders backrest and the nearly new highway pegs that I took off the '22. I also took the nearly new Vance and Hines mufflers off the '22 and put the stock mufflers on it. The Vance and Hines are the same for this bike also. It is surprisingly loud as is but I''ll probably swap them tomorrow to see how they sound on this bike. I think they had a deeper tone. I went back and forth on the color but ended up buying Iron Horse Metallic.
  14. Would $40 for the carb tuner be reasonable?
  15. Small as it was, It was great to meet up with those who did attend. It may not be as big a gathering as it once was but its nice that some friendships made in previous years still remain today. Thanks Phyill but making the effort to bring us together.
  16. Thank you, I did notice late last night oil getting into that section after cranking the motor enough. That cover is now back on. Now I just need help identifying the coil for ledt and right on the front cylinders
  17. N3FOL
    New Bike
    He is really doing the right thing. Baby steps on riding and safety. He is lucky to have you as a mentor for life. This sounds to me that Don is back on the saddle. Enjoy the experience of a lifetime with your son.
  18. Engine and transmission share the same oil. No separate change required. Notchy shifting/hard to find neutral conditions let you know your oil change is overdue.
  19. Turned out to be good day at Ontario greet! 5 members and a guest showed up! 3 vehicles and 3 bikes! Here are some pictures taken!
  20. OK, so I am in the mist of my rebuild I have hit 2 road blocks, I am really hoping someone can point in the correct direction. 2000 venture btw. 1) I have moved things around enough that I have lost track of which ignition coil is for the left and right side on the front of the motor. My coil sit on the back bone, one above and slightly aft, the other below slightly forward. I am thinking the one on top is for the left cylinder. Please let me know if you know. 2) I am having trouble identifying the oil for the transmission, some of this may because I am used to using different terminology than the service manual. I am seeing 2 different things. One is that the final drive use an SAE 80 gear but if I am looking at this right, that is the hub/differential for the rear wheel. I am also seeing the area in question being called the middle drive. I read that this uses the same oil as the motor. Does that mean oil from the motor is being pumped to the transmission? With a separate fill cap behind the chrome cover with the oil fill cap, I am guessing I need to place oil in the transmission, but what kind? Oil is currently in the motor and the second cover on the left is off and no oil is coming out. Thanks in advance
  21. Great bike!
  22. Well, not for me but it’s now in my garage. Ny son Dylan turned 30 two days ago and decided he wants to start riding. Can’t say that I was really in favor but he’s an adult and makes his own decisions. So he found a 2024 Ninja 500 with 1684 miles on it in Pittsburgh, PA. This morning we hooked up the trailer and went after it. The bike is like brand new with a couple of tasteful upgrades. At least he’s doing the right things. Next week or the week after he is signed up for the beginners rider course and won’t be riding it except maybe a couple of short rides here on the country roads around my house.
  23. Will definitely miss seeing that fussy hat. Condolences to his familly..
  24. Good evening to all! Today, Wednesday, July 30, 2025, is the hottest day of the week (at least in our area here in SE Pa.). With that said, the weather folks stated there is light at the end of the tunnel. By the end of the week, this coming Friday's high will strangely be in the lower 70's for a high. Thank God for the cold front that will blanket the area by Friday. You know what that means... time to cut the grass once again and wash the family minivan and not suffer from any potential heat stroke. . This Friday is the big day. lol Stay cool. Stay Hydrated and be weather informed. Ride safe to wherever your destination may be.
  25. I purchased a 2018 Venture in December. It is time for a new rear tire. I down loaded the service manual that someone was nice enough to put on this site. The rear wheel removal doesn't look to bad but I hate surprises. It looks like you remove saddle bags and mufflers. It says to remove rear wheel sensor and lead then the rear brake caliper. Then loosen the drive belt adjusting locknut and nut. Then remove axle nut and then axle. Then remove rear wheel. Are there any other parts that are going to fall off or out when you remove the wheel? Any thoughts or advise would be helpful. Do you need to remove the rear wheel belt pulley before you take it into the shop to have the new tire put on?
  26. Looking forward to meeting up with whoever shows tomorrow! Looking forward to Ice-cream also! Good riding and be safe!!
  27. We ended up getting a couple of LS2 Advant-x helmets in matte black. I'll be riding up to the cabin with friends this weekend so I'll break it in. Seems very soft, comfortable but a bit tight on the cheeks, sales guy says that'll get better after a bit of use. Dangerous stuff going into Iron Pony Motorsports.....They had a burgandy Can Am Spyder Limited ......Damn, it was nice. Not quite ready yet, but if I was, I'd have pulled the trigger on that right on the spot.
  28. Woody
    Vogel 2025
    Paul, we hate to hear that but maybe later. Next year we should be back at Asheville but where ever we are you will be welcome to join us.
  29. @Wizard765is asking if anyone showing up Thursday is bringing their wives?
  1. Load more activity
