This stream auto-updates
  1. Today
  2. So my 98 RSTD is running great...but...it has a tendency to quit or become very difficult to start once the engine and rad are heated. I have heard from another member with this era of RSTD the location of the ignition can be a problem due to excessive heat from the motor and rad. So my question is can the ignition be relocated and if so, is there anyplace on the forum or elsewhere to get the info. I've looked but so far nada, bupkus, squat, diddly, zero. Thanks in advance.
  3. Yesterday
  4. So the 2022 Road Glide Limited is gone. I had strongly been considering saying goodbye to my riding days for some time now. The Road Glide Limited was a great long range touring manchine but now that I've turned 70, it sure was feeling heavy on these. short rides around home. So it was time to let it go. So my riding days are over. But Nay Nay say I. Today I picked up a slightly lighter bike. It is still HEAVY but feels 300 pounds lighter than the limited due to having no tour pack and them lightening the fairing by about 20 lbs. One test ride was all it took and I was sold. It has three factory ride modes. Sport, Rain, and Highway. Plus another one that you can customize to your liking. The salesman told me that in sport mode, Harley has everything dialed up to about 80%. He created a custom mode for me where he set throttle response and everything to 100% and the performance was amazing. It is really too much unless you really want to play hard. I actually put it back into Sports mode and even highway mode on the way home. So what did I buy? A 2025 Harley Road Glide and I have to say I love this thing. It has the new 117 Cu In motor with 105 HP and 130 lbs of torque. It actually feels even stronger. All the modern goodies. ABS, Traction Control, etc. Apple car play, navigation, etc. 12" digital screen that you can customize to your liking. They upgraded the front and rear suspension and added an additional 3 1/2 " travel to the rear. I am just completely impressed with this bike. I got them, to throw in a passenger backrest and a taller "Klock Werks" windshield. Since taking these pictures, I added a riders backrest and the nearly new highway pegs that I took off the '22. I also took the nearly new Vance and Hines mufflers off the '22 and put the stock mufflers on it. The Vance and Hines are the same for this bike also. It is surprisingly loud as is but I''ll probably swap them tomorrow to see how they sound on this bike. I think they had a deeper tone. I went back and forth on the color but ended up buying Iron Horse Metallic.
  5. Would $40 for the carb tuner be reasonable?
  6. Small as it was, It was great to meet up with those who did attend. It may not be as big a gathering as it once was but its nice that some friendships made in previous years still remain today. Thanks Phyill but making the effort to bring us together.
  7. Thank you, I did notice late last night oil getting into that section after cranking the motor enough. That cover is now back on. Now I just need help identifying the coil for ledt and right on the front cylinders
  8. N3FOL
    New Bike
    He is really doing the right thing. Baby steps on riding and safety. He is lucky to have you as a mentor for life. This sounds to me that Don is back on the saddle. Enjoy the experience of a lifetime with your son.
  9. Engine and transmission share the same oil. No separate change required. Notchy shifting/hard to find neutral conditions let you know your oil change is overdue.
  10. Turned out to be good day at Ontario greet! 5 members and a guest showed up! 3 vehicles and 3 bikes! Here are some pictures taken!
  11. OK, so I am in the mist of my rebuild I have hit 2 road blocks, I am really hoping someone can point in the correct direction. 2000 venture btw. 1) I have moved things around enough that I have lost track of which ignition coil is for the left and right side on the front of the motor. My coil sit on the back bone, one above and slightly aft, the other below slightly forward. I am thinking the one on top is for the left cylinder. Please let me know if you know. 2) I am having trouble identifying the oil for the transmission, some of this may because I am used to using different terminology than the service manual. I am seeing 2 different things. One is that the final drive use an SAE 80 gear but if I am looking at this right, that is the hub/differential for the rear wheel. I am also seeing the area in question being called the middle drive. I read that this uses the same oil as the motor. Does that mean oil from the motor is being pumped to the transmission? With a separate fill cap behind the chrome cover with the oil fill cap, I am guessing I need to place oil in the transmission, but what kind? Oil is currently in the motor and the second cover on the left is off and no oil is coming out. Thanks in advance
  12. Last week
  13. Great bike!
  14. Well, not for me but it’s now in my garage. Ny son Dylan turned 30 two days ago and decided he wants to start riding. Can’t say that I was really in favor but he’s an adult and makes his own decisions. So he found a 2024 Ninja 500 with 1684 miles on it in Pittsburgh, PA. This morning we hooked up the trailer and went after it. The bike is like brand new with a couple of tasteful upgrades. At least he’s doing the right things. Next week or the week after he is signed up for the beginners rider course and won’t be riding it except maybe a couple of short rides here on the country roads around my house.
  15. Will definitely miss seeing that fussy hat. Condolences to his familly..
  16. Good evening to all! Today, Wednesday, July 30, 2025, is the hottest day of the week (at least in our area here in SE Pa.). With that said, the weather folks stated there is light at the end of the tunnel. By the end of the week, this coming Friday's high will strangely be in the lower 70's for a high. Thank God for the cold front that will blanket the area by Friday. You know what that means... time to cut the grass once again and wash the family minivan and not suffer from any potential heat stroke. . This Friday is the big day. lol Stay cool. Stay Hydrated and be weather informed. Ride safe to wherever your destination may be.
  17. I purchased a 2018 Venture in December. It is time for a new rear tire. I down loaded the service manual that someone was nice enough to put on this site. The rear wheel removal doesn't look to bad but I hate surprises. It looks like you remove saddle bags and mufflers. It says to remove rear wheel sensor and lead then the rear brake caliper. Then loosen the drive belt adjusting locknut and nut. Then remove axle nut and then axle. Then remove rear wheel. Are there any other parts that are going to fall off or out when you remove the wheel? Any thoughts or advise would be helpful. Do you need to remove the rear wheel belt pulley before you take it into the shop to have the new tire put on?
  18. Looking forward to meeting up with whoever shows tomorrow! Looking forward to Ice-cream also! Good riding and be safe!!
  19. We ended up getting a couple of LS2 Advant-x helmets in matte black. I'll be riding up to the cabin with friends this weekend so I'll break it in. Seems very soft, comfortable but a bit tight on the cheeks, sales guy says that'll get better after a bit of use. Dangerous stuff going into Iron Pony Motorsports.....They had a burgandy Can Am Spyder Limited ......Damn, it was nice. Not quite ready yet, but if I was, I'd have pulled the trigger on that right on the spot.
  20. Woody
    Vogel 2025
    Paul, we hate to hear that but maybe later. Next year we should be back at Asheville but where ever we are you will be welcome to join us.
  21. @Wizard765is asking if anyone showing up Thursday is bringing their wives?
  22. Sorry, I thought I posted where and when! Figured same as we usually go but forgot about people who haven't been before! (This is why I let others do planning) Coffee at Tim Hortons at 1084 Rest Acres Rd Paris Ontario. If comming 403 highway from West take 24 North turn-off, then I think 2 or 3 roundabouts and Tim's is on left side in plaza. East bound 403 take 24 North turn off go 2 roundabouts and is on left side in plaza. Ice-cream will be at Paris Twisted Treats 98 Scott Ave. It is in North end of Paris. Can find these spots on Google Maps also!
  23. Forgot that I had this thing sitting in a drawer, don't think I ever used it. Sold the bike, so I don't need this anymore. It's in perfect condition. $90.00 Cdn.
  24. I was a goin' to Vogel this year for the very first time, but have had to change plans and will not make it - maybe next year. I did just cancel the room reservation at Seasons Inn this afternoon if anyone here is looking to stay there.
  25. Good evening to all! Started yesterday and finished today. Replaced plugs on the RSV and SVTC. Installed D2 Denali and SoundBomb horn on the SVTC. Despite the heat in the garage, it was fun working on the install. Didn't get the chance to install the Denali SoundBomb on the RSV since I don't have the right bracket for it. Will order the correct bracket online by tonight. So happy how they both turned out. IMG_1223.MP4
  26. The 88 Venture Royale is starting to feel pretty wore down with 106k miles. Engine wise she feels strong, but its needing more and more TLC in the suspension and electronics department. I know it'll go another 100k miles, and i'll never sell this venture, but we will certainly be upgrading to a 2021+ goldwing soon
  27. Sorry to hear! Condolences to his family!!
  28. Woody
    Vogel 2025
    Clean out the front of the camper and repacked it yesterday
  1. Load more activity
