This stream auto-updates
  1. Yesterday
  2. Is @skydoc_17 still in business with products for us?
  3. Last week
  4. I've never really seen the insides of a Stator. Thanks for sharing the pics. Looks to me there are a few burnt coil windings. Best of luck on your project. Looks like you are getting closer to replacing the main objective. This afternoon, I was able to change oil on the SVTC. Used T6 Rotella.
  5. @Marcarl I thought so too!
  6. That stator looks a little toasty!!
  7. That stator looks a little toasty!!
  8. Finally figured how to get clamp opened to get wires out! Was a real pain disconnecting tha small 2 wire plug that had to come out with Stator!
  9. Got Stator cover 1 off and this is picture of Stator! Now to clean off gasket and then replace Stator!
  10. Pictures of antifreeze being soaked up on bike table and one of dirty wires! Still trying to get them loose from clamp then I can pull them out to remove Stator! Had to pickup son's rototiller as he needs it for weekend if weather is good!
  11. Yes it is getting exciting! Should have realized that the pressure behind the plug would want to go somewhere! Should have put the covers on until I had to put exhaust back on! Picked up tube of RTV and blue Lock Tite for the rubber plugs in Stator!(going to try and vacuum seal them after use as am hoping them to last without hardening as I don't use them enough)
  12. Now it is getting more exciting. Thanks for telling us the 'Play-by-Play' as you progress through your project.
  13. Been busy all day today and finnaly went out to do some more work on bike and now I have to add putting Antifreeze in when I'm done with Stator! Took off engine fins off to remove exhaust and didn't put it back on and freeze plug fell out sometime and drained Antifreeze! Wiped up the mess,dried off tools and wiped down drain hoses that went thru frame so I have a little more room to try tomorrow to get wires out so I can get Stator out!
  14. I just sold my 07. It took several weeks as big bikes just aren’t selling well. Had to turn down several lowball “offers” and wait for the right person that really wanted it. Friend has a 2010 HD Ultra that’s been on the market for a year. Hope yours sells quickly.
  15. before and after cover2 and piece behind it
  16. Came back in from garage around9pm after I took out overflow tank to get better access to wiring,pulled bolt holding wiring to drive-shaft housing but having hard time figuring how it is holding wires,saw pictures of this area but can't find it yet! Cleaned all crud off of Cover2 and scraped off old gasket. Cleaned some of the frame and wires ,also cleaned some of the oil pan also! Finally came in as back can't do long stints like I used to,even with bike on table about 24 to 30in off the ground! At least I'm not on the ground doing this! Have to take dog to groomers tomorrow so won't get much done tomorrow but will try to do what I can!
  17. Earlier
  18. Good riding weather is here, this is a great bike and road ready.
  19. Got garage organized enough to have more than enough room and places to put parts on when dismantling what I need to take off! Punched holes in small box to hold bolts in order of disassembly! After taking farthest chrome part(half moon shaped) from cover2 looks like there was a small leak somewhere as there is a LOT of crud on it and everything under bike! Have oil drained,exhaust disconnected, all bolts except one each cover till ready to take off and also make sure all oil is drained then will try to clean all crud from oil pan,frame ,hoses and wires before I get too far!
  20. Even MORE important that "Bought a Gold Wing" (I know that's hard to believe.....), is "WHERE ARE YOU"?? I'd be waaaaaaaaaaaaay more interested if I can scoot over and have a look at these than if I have to drive to Utah (from Niagara Falls!)
  21. I gave him the info. Pretty sure he’ll show up here. We talked about good knowledgeable factual information vs facebook information. Now I need to move out 2 more for even more room. Got a 1st gen and a Honda to move.
  22. Got more room now, are they a member here or maybe gonna be
  23. she got a new owner today at 87,000 miles. 🥹
  24. It's not too difficult to make an adapter to fit most motorcycle lifts.
  1. Load more activity
