VentureRider.Org Cruiser Customizing
Home Venture History Classifieds Links VRAwards VRPhotos VRChat VRStore Donate
Go Back   VentureRider.Org > General Discussion > Watering Hole
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 12,557 Entries 0
Members Entries
Threads 51,600 Reviews 0
Threads Reviews
Posts 614,353 Polls 45
Posts Polls
Content 0 Files 0
Content Files
Links 64 Ads 0
Links Ads
More...
  #1
Old 11-09-2009, 06:50 PM
Goofeychuck Goofeychuck is offline
Default shock pressure
what are the pressures that I should have in the front and rear shocks?
Riding empty and alone and with a passenger?
  #2
Old 11-09-2009, 07:05 PM
sarges46's Avatar
sarges46 sarges46 is offline
07 Blue RSV
sarges46 has a Profile Picture
Supporting Member
Default
Front as low as 0 to max of 7lbs
Rear....
It all depends on how you like the ride. Best to experiment.....sorry for the poor answer.
__________________
All the best
Rick
sarges46
UBIQUE
  #3
Old 11-09-2009, 07:07 PM
Eck's Avatar
Eck Eck is offline
Moderator - 2002 Goldwing
Eck has a Profile Picture
Supporting Member
Default
Just my opinion..and I'm sure others will have theirs....
Riding by yourself = 3 lbs front and 25 lbs rear
Riding with passenger = 3 lbs front and 25 to 30 lbs rear
  #4
Old 11-09-2009, 07:37 PM
stroker ace's Avatar
stroker ace stroker ace is offline
stroker ace has a Profile Picture
Location: Find stroker ace on Google Maps! Oliver Springs
Default
By myself 5 front 45 rear
Two up 3 front 45 rear
Fully loaded 3 front 45 rear
That's with Metzler Tires 40 front 45 rear run other pressures with other tires. my
  #5
Old 11-09-2009, 07:50 PM
footsie footsie is offline
Supporting Member
Default Zero
I run 0 in both
  #6
Old 11-09-2009, 08:09 PM
edger edger is offline
Default
Just don't go over 7 front and 50 rear. Those are the max's according to the manual anyway.
  #7
Old 12-31-2009, 12:58 PM
Brake Pad's Avatar
Brake Pad Brake Pad is online now
2012 Honda Goldwing
Brake Pad has a Profile Picture
Supporting Member
Location: Find Brake Pad on Google Maps! 4820 55th st. Vero Beach, Fl 32967
Default
Lets open up this board again.
I have the 2007
Knowing its under warranty, the shop has me watching the front shocks.. started with front end shake (maybe the new front tire?) Had it balanced, alittle better....
shocks lost half its air. shop said the front should have max 10 lbs up front, and up to 50 in rear shocks ( 50 fells okay), but front shock makes the bike fell like (squermmy)?
It fells like, the tires are slipping (like on oil) for a split second, every few, feet.
Been riding secondary roads, and staying off the highways, til I figure it out.
when I bring it into the shop next week, I'm going to have them also check the front bearings AGAIN!!! and the swing arm & rear Hub ( new tire)
anyone have something like this happen to them?
__________________
  #8
Old 12-31-2009, 01:12 PM
Freebird's Avatar
Freebird Freebird is offline
ADMIN - 2013 Road Glide Ultra
Freebird has a Profile Picture
Supporting Member
Default
Well...to start with...your shop needs to read the manual. Max PSI for the front shocks is 7 psi. I wouldn't think that 10 would have blown the seals but it may have. I typically run about 35 psi in the rear and usually zero in the front.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
replacing rear air shock with standard shock deorto First Generation Venture Tech Talk 6 06-24-2014 09:10 AM
Shock absorber air riding pressure RSTD 05 piper Royal Star and Royal Star Tour Deluxe Tech Talk 0 11-17-2008 12:55 AM
Rear Shock Air Pressure CelticDude Royal Star and Royal Star Tour Deluxe Tech Talk 21 03-24-2008 11:25 AM
pressure bleeds off of rear shock TxVenture First Generation Venture Tech Talk 4 01-30-2008 05:16 AM
help , oil pressure Thom First Generation Venture Tech Talk 14 11-26-2007 07:35 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright 2004 VentureRider.org
