Gdserlin Posted September 1, 2008 Share #1 Posted September 1, 2008 I am attempting to upgrade the glass fuse box to a plastic Buss type. I read a thread awhile back where one of the members did this, but of course I cannot now find it. Here is my issue. The original glass fuse block isolates the incoming power for each circuit, ie, headlight, turn, brake, ignition etc.. The replacement block has one incoming terminal for all outputs. There is no way to isolate the incoming power for each circuit. I determined that with the exception of the accessory circuit, the remaining circuits are all hot once the ignition is switched to the on position. The accessory circuit is hot (not surprisingly) once the key is turned to ACC. I could isolate the Accessory circuit with those individual rubber blade type fuse sockets and run the remaining circuits through the new block. My thought was to simply strip the wires, wind them together solder them to a heavier gauge wire and terminate at the hot terminal on the new block. I am hesitant to this because somewhere along the line I thought I read that there was a reason each of the circuits has its own individual hot feed in the original glass fuse box, in particular the lighting circuit. I don’t want to fry anything and somehow I think my plan is to easy. Any ideas out there? Link to comment Share on other sites More sharing options...
hipshot Posted September 1, 2008 Share #2 Posted September 1, 2008 Gerry. i ran into the same problem. in order to get the correct fuse block(individual circuits), the Yamaha marine dealer would have had to special order it! $78.00 and change! since the only circuit on my bike that was actually bad, was the headlight fuse, i simply bough an inline blade type fuse and fuse holder,and soldered it in place of the glass fuse. just jt Link to comment Share on other sites More sharing options...
Thom Posted September 1, 2008 Share #3 Posted September 1, 2008 i can not remember who , but i saw somebody at Asheville did the 1 input wire and it seem to work ok , i think it was ABC ? Thom Link to comment Share on other sites More sharing options...
cecdoo Posted September 1, 2008 Share #4 Posted September 1, 2008 Terminal Supply has a block for about 13 bucks that works great, I think Squidley knows the #s. Think there is an article in the 1st gen tech section. Craig Link to comment Share on other sites More sharing options...
GeorgeS Posted September 2, 2008 Share #5 Posted September 2, 2008 Most auto parts stores, carry an ATM type 6 position generic fuse holder. Link to comment Share on other sites More sharing options...
Gdserlin Posted September 2, 2008 Author Share #6 Posted September 2, 2008 Thanks guys. Unless someone tells me its going to cause havok, I am going to try the one input wire block. I checked the wiring diagram and I do not see any likelyhood of it interfering, but I guess I will find out if I am wrong...................... Link to comment Share on other sites More sharing options...
Squidley Posted September 2, 2008 Share #7 Posted September 2, 2008 Gerry, here's a pic of my '86 whereI changed it over to spade fuses. Here is where I bought it, they also have a 6 position but I liked having the 8 one for additional uses. http://terminalsupplyco.com/Store/Product.aspx?pc=ATO-FB8 Link to comment Share on other sites More sharing options...
Dano Posted September 2, 2008 Share #8 Posted September 2, 2008 I thought somebody said that NAPA carries one? Link to comment Share on other sites More sharing options...
wkoepke Posted September 2, 2008 Share #9 Posted September 2, 2008 i tied all the wires together on my 86 about 2 months ago and it has worked out just fine.have not noticed any heat in the wires so you should be ok. Link to comment Share on other sites More sharing options...
