skydoc_17 Posted November 11, 2018 Posted November 11, 2018 When you roll on the throttle of your Second Gen. RSV or RSTD does the clutch slip? When you "briskly" go from first to second gear does your clutch slip? Do you ride 2 up often? Are you trying to pull a trailer and is your clutch slipping? Are you thinking about paying $300.00 plus the install for a Barnett Clutch, well think again! The stock Yamaha clutch is a high quality part and will last up to 100,000 miles. The problem is not your clutch; It's the clutch basket diaphragm spring and that "wimpy" half disc that has failed. So here's the fix! Install an aftermarket, thicker clutch diaphragm spring, and full clutch disc and never worry about that RSV or RSTD or RSTC clutch again! The heavy duty clutch diaphragm spring puts 25% more clamping force on the clutch discs than the stock RSV clutch spring. Here's my deal, you get a brand new .070” thick heavy duty clutch diaphragm spring, (name brand) a new full clutch friction disc to replace the half disc, and a brand new, genuine Yamaha replacement clutch cover gasket, everything you need to do this install for $115.00 including shipping in the USA!!! I will include complete written instructions, and i have a picture file that can be downloaded! what a deal!! If you have some miles on your current set of friction discs, check my other MEMBER VENDOR Classified Ads for the remaining 7 genuine Yamaha friction discs or the seven steel clutch plates for $105.00 a set each, Making this upgrade basically, a brand new, better that stock clutch! This upgrade can be done in less than 2 hours, doesn't require the removal of the clutch basket, can be done with a 10mm and 12mm wrench and an allen wrench, and a pair of needle nosed pliers and side cutters and you will loose very little engine oil! Shipping in the 48 states is free, outside the us is at actual cost! I accept paypal and checks! Thanks for viewing my ad. Earl (skydoc_17) 2
DaveRSTD Posted July 22, 2019 Posted July 22, 2019 Hi Earl, are you still offering the clutch upgrade? My clutch slips a little in 5th gear when i hammer it. The whine has gotten worse as well so i hope this might scale it back a little. i have a 2006 RSTD. Thanks, Dave
VaRider Posted November 6, 2019 Posted November 6, 2019 Hi Earl, are you still offering the clutch upgrade? Does this help the whine? Thanks
saddlebum Posted April 13, 2021 Posted April 13, 2021 5 hours ago, Phil Lidde said: How do I order the clutch kit? @skydoc_17Something tells me you may have the answer. 1
skydoc_17 Posted September 28, 2022 Author Posted September 28, 2022 Hey John, I sent you a PM with the clutch kit details. Let me know if I can help! Earl 1
tractoratvman Posted July 22, 2023 Posted July 22, 2023 Hi skydoc_17 I tried to message you directly and it won't let me/I can't figure it out🤷♂️. I'm very interested in your clutch kit. I just bought a 2007 and if I get on it really hard it will slip and with only 32,000 miles I figure your kit should work great!!
skydoc_17 Posted July 22, 2023 Author Posted July 22, 2023 Hey Dan, Welcome to the Forum! I think because you are a Trial Member, it will not let you PM until you join the group, but that's just a guess. I actually offer four kits for the Second Gens. depending on how many miles you have on your current clutch, and the type of riding you do. The first kit is the Heavy Duty Clutch Diaphragm Spring, one FULL Clutch Friction Disc to replace the 1/2 disc in the rear of the Clutch Pac, and a Genuine Yamaha Clutch Cover Gasket. This Kit sells for $115.00 The Second Kit I offer is the remaining 7 Clutch Friction Discs which when added to the first kit will result in a Clutch System that is 35% stronger than a new stock clutch! This kit is $105.00 The third kit I offer is the 7 Steel Clutch Plates. If you ride 2up fully loaded or pull a trailer, this third kit would restore your Clutch System to "Better than New" condition. This Kit is $105.00 In addition to the three kits, I also offer the 6 Pressure Plate Retaining Bolts. These bolts were intended to be a “One Time Use Only” item. So it’s up to you weather you change them out or not. This 4th kit is $20.00. Just off the top of my head Dan, I'd say that kits #1 and #2 would bring you back to "Better Than New"! I would add the 4th kit if you aren't feeling lucky. The 4th kit is your call. My personal email address is skydoc17@gmail.com Let me know if I can help you with this project Dan, Earl. (skydoc_17)
PurpleNo17 Posted August 6, 2023 Posted August 6, 2023 Howdy! I ordered kit 1 from you awhile back and I want to order the additional plates and steels (kit 2 &3)with bolts. How do I go about ordering and what’s the turn around time? 😉 (Ride coming up with wife and trailer👍)
skydoc_17 Posted August 6, 2023 Author Posted August 6, 2023 Hey Doug, It's nice to hear from you again! I have those kits in stock and can ship as soon as Payment is received! My PayPal email address is: earlfharrell@atlanticbb.net The total cost is $210. for the two kits, and $18. to ship. I can ship this as soon as Monday Morning! Let me know if I can help Doug, Earl.
PurpleNo17 Posted August 7, 2023 Posted August 7, 2023 Howdy! I ordered kit 1 from you awhile back and I want to order the additional plates and steels (kit 2 &3)with bolts. How do I go about ordering and what’s the turn around time? 😉 (Ride coming up with wife and trailer👍) Good deal Earl! I want your bolt kit also so give me a total and I will get it to you. Is there anything else you need?
skydoc_17 Posted August 7, 2023 Author Posted August 7, 2023 Hey Doug, Kits #2 and #3- $210. Bolt Kit- $20. Shipping- $18. Total: $248.00 A Shipping Address would help. My PayPal email address is: earlfharrell@atlanticbb.net Thanks Doug for letting me help you with this project! Earl,
skydoc_17 Posted August 7, 2023 Author Posted August 7, 2023 Hey Doug, PayPal Payment received, kits shipped. Will arrive Thursday, the 10th. www.usps.com Tracking Number is: 9505 5139 3871 3219 5646 15 Any Questions, Let me know, Earl.
Barnacle442 Posted August 8, 2023 Posted August 8, 2023 I have a question regarding the 2nd Gen clutch system. You all seem like learned men of science. I have done four clutch replacements, so far. I have installed that retaining wire four times, (If you have ever worked on one of these clutches you know the wire I am talking about.) What is the purpose of that retaining wire? That last plate isn't going anywhere. It is a royal star pain in the ass to get back in there but it has to have a purpose, right? I am tempted to leave it out but I have developed an allergy to stranding myself hundreds of miles from home.
RDawson Posted August 8, 2023 Posted August 8, 2023 7 minutes ago, Barnacle442 said: I have a question regarding the 2nd Gen clutch system. You all seem like learned men of science. I have done four clutch replacements, so far. I have installed that retaining wire four times, (If you have ever worked on one of these clutches you know the wire I am talking about.) What is the purpose of that retaining wire? That last plate isn't going anywhere. It is a royal star pain in the ass to get back in there but it has to have a purpose, right? I am tempted to leave it out but I have developed an allergy to stranding myself hundreds of miles from home. I did Skydoc’s full disc conversion and left the wire out about 50,000 miles ago. Hasn’t stranded me yet.
PurpleNo17 Posted August 14, 2023 Posted August 14, 2023 Hey Skydoc! Finally got some time for clutch install. Thanks for help again. And Barnacle, if you read this I am sorry I didn’t respond earlier. Your questions are covered well in a Tech Post titled “Clutch Upgrade” under Second Gen, engine and drivetrain. Thanks to Freebird!
MassterBrewer12 Posted July 26, 2024 Posted July 26, 2024 Hey Earl. I'd be interested in these one of your clutch kits if you're still making them. Let me know.
