Mopar4ever Posted May 17, 2017 Posted May 17, 2017 Ok looked through and found where and how to fix the front brake light switch. Went to do this, and a PO has trashed the housing for the switch. So looks like I need a new one. Four wire switch for cruise control on an 84. Any idea where a poor Canuck could find this switch? Rear works fine so I'm not desperate, but I'd like to get it working.
Mopar4ever Posted May 17, 2017 Author Posted May 17, 2017 Forgot to mention I have a two wire switch that came with the bike, but not sure I want to try jury rigging it just to get the light working.
Flyinfool Posted May 18, 2017 Posted May 18, 2017 IF desperation does kick in................... I just bought an aftermarket front master upgrade, it has only a 2 wire switch. So I will be connecting that switch to operate the brake light, and using the brake light to drive a relay to operate the cruise kill.
Mopar4ever Posted May 18, 2017 Author Posted May 18, 2017 IF desperation does kick in................... I just bought an aftermarket front master upgrade, it has only a 2 wire switch. So I will be connecting that switch to operate the brake light, and using the brake light to drive a relay to operate the cruise kill. not sure I care about the cruise, but that's because I've never had it on a bike. Maybe I'd like it LOL. Sure would have been a bad idea on the ZX-14 anyway ...... 230 kph, set cruise LOL. ill have a look at it, and if I could use the two wire without causing any other problems, I might just throw it in for now.
Flyinfool Posted May 19, 2017 Posted May 19, 2017 If you do not have cruise or care about it then you only need a 2 wire switch. The other 2 wires are just to kill the cruise when you hit the brake.
Mopar4ever Posted May 19, 2017 Author Posted May 19, 2017 If you do not have cruise or care about it then you only need a 2 wire switch. The other 2 wires are just to kill the cruise when you hit the brake. Cool, I can get it working for now and track down the proper switch later if I decide I want try the cruise out. Or do as you're planning and add a relay later.
paysaw Posted May 25, 2017 Posted May 25, 2017 Hi.You may be able to track one down on Ebay. I had the same problem with my 86 and actually rebuilt the switch and springs.I cleaned up the contacts and remelted the plastic so it would work fine.I never had a problem after.One of the contacts are high current. Good luck with it.
84VentureMatt Posted October 7, 2021 Posted October 7, 2021 I've got a 84 PO had serviced prior to my purchase an was told the switch was toast an part is unavailable so has anyone come up with any solutions on this issue because I would really like both my brake switches functioning
Pasta Burner Posted October 9, 2021 Posted October 9, 2021 (edited) On 10/6/2021 at 11:53 PM, 84VentureMatt said: I've got a 84 PO had serviced prior to my purchase an was told the switch was toast an part is unavailable so has anyone come up with any solutions on this issue because I would really like both my brake switches functioning I would try cleaning it and make sure it isn’t sticking. Also check to make sure the lever is positioned correctly. I had the same issue with my clutch switch, I think they’re the same. It’s a very simple push button switch, not much to go wrong. Although the housing can crack easily so beware of that. Edited October 9, 2021 by Pasta Burner
