mellco Posted April 17, 2008 Share #1 Posted April 17, 2008 Hi, Thanks for the info on the "erratic fuel guage" found that the ground wire on the sending unit was bad. Now to my current problem: when I started the bike for the first time it ran poorly and would only stay running with the choke on. I have since changed the spark plugs, fuel filter, air filter and syncroniszed the carbs. The bike when cold runs bad(misses) when it warms up it does not respond well to throttle input and smells rich. If I hold the throttle at 3k rpms the bike has a miss that you can hear in the exaust. I have owned this bike for 4 years and it has always run great. Im stumped! Myrtle Beach is 3 weeks away and I was riding down and need to resolve this. Link to comment Share on other sites More sharing options...
davepa Posted April 18, 2008 Share #2 Posted April 18, 2008 I am looking forward to the answer! I have an 87' doing the same thing.... Link to comment Share on other sites More sharing options...
BuddyRich Posted April 18, 2008 Share #3 Posted April 18, 2008 I know the first gens are sensitive to the air cleaner box leaking. I would check to be sure its sealed good Link to comment Share on other sites More sharing options...
GeorgeS Posted April 18, 2008 Share #4 Posted April 18, 2008 Give the Ingnition Switch, and the Run - Stop Switch a " BATH " with CRC 2-26. Read Resistance from the 4 Center Pins of the 8 Pin plug of the TCI, to the + Bat. cable after removeing it from the battery. You should see 3.8 to 4.5 ohms. Thats the resistance of th Primary Coil Windings. You might have a Coil going bad Remove the TCI, and Dry it out. Clean the contacts at the TCI. Check the plug between the Alternator, and the Regulator. Check the 5 wire plug in cable from Pick up coils, going to the 6 pin plug of the TCI. Maby bad plug wires. Maby bad plugs. Link to comment Share on other sites More sharing options...
dray Posted April 18, 2008 Share #5 Posted April 18, 2008 SEAFOAM Link to comment Share on other sites More sharing options...
mellco Posted April 19, 2008 Author Share #6 Posted April 19, 2008 Hi Guys, Problem solved!!! Found the diaphram in carb #4 Had come apart? Looking at pictures of diaphrams they all appear to be one piece,This one was in 4! I put them all back together and still had a pop in airbox from carb #4. Prior owner had remover plugs for mixture screws. I checked screw for #4 and found it all the way in. Backed it out 2-1/2 turns checked the rest of the mixture screws and found all of them less than 1-1/2 turns out. Adjusted all of them, re-syncronized the carbs and the bike runs great. Thank you all for your input. Looking forward to Myrtle Beach!!! Link to comment Share on other sites More sharing options...
GeorgeS Posted April 19, 2008 Share #7 Posted April 19, 2008 But still run a can of Sea-Foam !!! Its the right thing to do. Link to comment Share on other sites More sharing options...
mellco Posted April 19, 2008 Author Share #8 Posted April 19, 2008 Purchased 2 cans from Auto Zone this morning. Plan to run 2oz per gallon mixture. Thanks Link to comment Share on other sites More sharing options...
Squidley Posted April 19, 2008 Share #9 Posted April 19, 2008 Purchased 2 cans from Auto Zone this morning. Plan to run 2oz per gallon mixture. Thanks FWIW.... Dont waste your time with measuring the seafoam, dump a full can into a full tank of gas. Granted that is a very concentrated mix, but will clean it up better than anything. I have always put an entire can in when I do it, and run it hard for at least 50 miles. I think your issue will be completely gone Link to comment Share on other sites More sharing options...
