MiCarl Posted October 13, 2016 Posted October 13, 2016 We're redoing our pontoon boat and I have a question about the dipole FM antenna for the radio. The dipole is 41" long but the widest dimension on the console is 28". If I put the antenna in the console it either needs to be cut or folded. In the old console it was shaped like figure A . This is looking down. It seems to me that "B" would be a better solution. I could stretch it out straight below the floor but I assume all the aluminum structure down there would create worse problems than bending or cutting it. Same problem with putting it in a seat - it'd be running parallel to an aluminum sheet. So do I bend it in a U as originally, make the Z shape in figure B, trim it or bend the ends downward? Thoughts?
ragtop69gs Posted October 13, 2016 Posted October 13, 2016 Carl, when I redid my Pontoon last spring, I ran into the same thing, what I did is to just staple it going around each way, they almost met at the front of the helm. Works great and no wadded up wire. Sent from my SM-N920V using Tapatalk
MiCarl Posted October 13, 2016 Author Posted October 13, 2016 Jay, The configuration in the old console seemed to be adequate too. But we keep the boat in the middle of Jackson County with most of the stations we want coming from Lansing 30 miles away. I want to make sure I get every bit extra I can.
snyper316 Posted October 14, 2016 Posted October 14, 2016 Question, what about bringing up and outward. I would think you would want to get it up in the air somehow. Like maybe window trim, or you does it have to remain under for a reason. Guy next door has ran up on the bow of his boat. Sent from my LG-K371 using Tapatalk
MiCarl Posted October 14, 2016 Author Posted October 14, 2016 Pontoon boat. Helm console is the highest point, other the Bimini which moves and has an aluminum framework.
ragtop69gs Posted October 14, 2016 Posted October 14, 2016 For the best reception you could always put a whip antenna on it. Sent from my SM-N920V using Tapatalk
Marcarl Posted October 14, 2016 Posted October 14, 2016 Can't you wire it direct? Just use a longer wire hello!
videoarizona Posted October 14, 2016 Posted October 14, 2016 For the best reception you could always put a whip antenna on it. Sent from my SM-N920V using Tapatalk Yep. Put up a VHF whip and get a splitter for the radio. They have nice mounts that also allow you to find down the antenna for bridges or trailering.
