Skid Posted April 22, 2016 Posted April 22, 2016 I have question concerning the deck belt & spring on a Yard Machine lawn mower. Yard Machine is made by MTD and doesn't have an idler pulley on the deck belt. My question is about the location for the spring to maintain tension on the deck. An in-law gave me mower because the drive belt was jumping off. I fixed that but there were two springs that wasn't on the mower when I got it. Doesn't anyone have one like this they can send pics of?
Flyinfool Posted April 22, 2016 Posted April 22, 2016 http://www.mtdparts.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10101&catalogId=19502&langId=-1 They have all the exploded views and you can order the springs while there.
Skid Posted April 22, 2016 Author Posted April 22, 2016 (edited) The problem I've ran into is that I can't read the model number I the tractor to get into the diagrams Edited April 23, 2016 by Skid
JDaniel Posted April 23, 2016 Posted April 23, 2016 With no hood there is plenty of room to add a blower or maybe a V8 or a turbo or a !!!
Yammer Dan Posted April 25, 2016 Posted April 25, 2016 My Cub Cadet took a notion to toss belt today. Seemed ok when I put it back but time for new one probally close.
Marcarl Posted April 25, 2016 Posted April 25, 2016 Maybe if you do a search on the engine model # it may give you model numbers of the units it's installed on.?.?
Skid Posted May 3, 2016 Author Posted May 3, 2016 I got the new wheel bushing today and replaced it so the tractor in up and running. I was able to obtain the model number 13A747GF062. Built in 1997 but still don't see where the springs go exactly
Marcarl Posted May 3, 2016 Posted May 3, 2016 Try looking here. http://www.mtdparts.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10101&catalogId=19502&langId=-1#/MTD_Merged_Data/13A747GF062_%281997%29/Frame_Assembly%2c_Drive%2c_Pedal_Assembly%2c_%26_Wheels%2c_Rear/010075500-B/0100755000020
Dragonslayer Posted May 3, 2016 Posted May 3, 2016 Here are the pics Oops disregard my early response that is a different machine then the one I have.Your on your own.
cowpuc Posted May 3, 2016 Posted May 3, 2016 Skidder,, it's entirely possible that someone added extra springs to the deck belt tensioner in a valiant attempt to hold the belt on and that is where your xtra springs came from - not an uncommon notion.. Also possible that they came from other "idler pulleys" associated with the deck belt that goes around the blade pulleys, clutch or even the drive belt that goes back to the tranny/axle. Look closely at all associated belt systems and if there was a spring attached to any of those idlers you should see a tell tale sign of such (holes or notches). Also could be that your relative had a child helping them when they last worked on it and the child was playing with the springs and just left em laying on the deck when he/she was finished helping - this has happened to many parents over the years!!
Skid Posted May 8, 2016 Author Posted May 8, 2016 There is no idler pulleys on this deck. I think it is supposed to have a brake, but the parts are missing. I'll have to wait to get a chance to see one similar to it to see for sure. Until it does work and mows good, the blades are just always spinning.
