Cassette door
I started with the storage mod from http://www.venturers.org/Tech_Library/?action=category&cat_id=002003 (link won't take you to page, so click "click here" at bottom of page, then "2nd Gen", then "audio/CB", then "cassette deck to storage mod") I installed a Shark audio system from http://sharkmotorcycleaudio.com/#_l_ce I think it worked out well. I have not had time to get out and test it log term yet, but works well in the garage.
Edited by Huked
Take apart the player and put the housing back in.
I did that last winter . I built up the inside and made a spot to put my wallet.
I also used a Y connector move the line in to down by the accessory plug and another run to the trunk
I tried to do that last year and couldn't get the door to slip through the hole ! :confused24:
I had to use a small flat screwdriver and life one corner then the other. It will go just needs to be persuaded.
