Kirby Posted April 17, 2016 Posted April 17, 2016 I've been thinking of removing my cassette player. Question is, Does the hinged door come off with the player? I'd like to keep the door if at all possible.
Zzyzx Posted April 18, 2016 Posted April 18, 2016 You can always cut the door off the cassette player and lock into place from the inside of the fairing or...add some gages to the open space.
djadam Posted April 18, 2016 Posted April 18, 2016 If you just remove the cassette deck and keep the housing, doesn't the door stay on the housing?
Huked Posted April 18, 2016 Posted April 18, 2016 (edited) I started with the storage mod from http://www.venturers.org/Tech_Library/?action=category&cat_id=002003 (link won't take you to page, so click "click here" at bottom of page, then "2nd Gen", then "audio/CB", then "cassette deck to storage mod") I installed a Shark audio system from http://sharkmotorcycleaudio.com/#_l_ce I think it worked out well. I have not had time to get out and test it log term yet, but works well in the garage. Edited April 18, 2016 by Huked
dave_wells Posted April 19, 2016 Posted April 19, 2016 Take apart the player and put the housing back in. I did that last winter . I built up the inside and made a spot to put my wallet. I also used a Y connector move the line in to down by the accessory plug and another run to the trunk
ragtop69gs Posted April 20, 2016 Posted April 20, 2016 Take apart the player and put the housing back in. I did that last winter . I built up the inside and made a spot to put my wallet. I also used a Y connector move the line in to down by the accessory plug and another run to the trunk I tried to do that last year and couldn't get the door to slip through the hole !
Huked Posted April 20, 2016 Posted April 20, 2016 I tried to do that last year and couldn't get the door to slip through the hole ! I had to use a small flat screwdriver and life one corner then the other. It will go just needs to be persuaded.
ragtop69gs Posted April 20, 2016 Posted April 20, 2016 Both myself and Carbon One tried, no go... Sent from my SM-N920V using Tapatalk
retrostude Posted April 21, 2016 Posted April 21, 2016 Both myself and Carbon One tried, no go... Sent from my SM-N920V using Tapatalk http://uploads.tapatalk-cdn.com/20160421/4d536ff9efcd926c218a6b292d4290ff.jpg My first gen solution Sent from my SCH-I535 using Tapatalk
