Brake Pad Posted May 31, 2015 Share #1 Posted May 31, 2015 this bike belongs to StarRiders bike he is one of my friends here in South Florida he recently had his faring in front and redone from a recent accident we're trying to figure out why the headlight sits so far back in the fair here are a few pictures I need help from some one that can give me close up pictures of the fairing Please cal Gary at: 954-804-2728 if you have any ideas that can help us out. split[ATTACH=CONFIG]99585[/ATTACH][ATTACH=CONFIG]99586[/ATTACH][ATTACH=CONFIG]99587[/ATTACH][ATTACH=CONFIG]99585[/ATTACH][ATTACH=CONFIG]99586[/ATTACH][ATTACH=CONFIG]99587[/ATTACH] Link to comment Share on other sites More sharing options...
ragtop69gs Posted May 31, 2015 Share #2 Posted May 31, 2015 Thats odd,,, The only reason I can come up with is that the plate the light bucket mounts to is either missing the rubber grommets the bolts go through or the plate is bent. Link to comment Share on other sites More sharing options...
Brake Pad Posted May 31, 2015 Author Share #3 Posted May 31, 2015 Okay we already know that the bolts are lined up correctly run into there , the plate is not bent. so keep the comments coming thank you Link to comment Share on other sites More sharing options...
Eck Posted May 31, 2015 Share #4 Posted May 31, 2015 Mike, I have to agree with what Ragtop69gs is trying to convey to you. You state the bolts are aligned up correctly. That I would have to agree with you on because the "entire" headlight assembly has been attached prior to the outer (front) fairing being put on. However, What ragtop69gs is trying to say is: The two upper mounting bolts (for attaching this "entire" head light bucket assembly), have ONE rubber spacers / grommets / bushings (whatever you want to call them) on each of the two bolts, and each grommet must have a flat washer. To install the entire headlight assembly correctly, each of the two mounting bolts first, MUST go through the head light mounting bracket, "THEN" secondly, each bolt MUST go through a rubber grommet/ bushing, THEN one must align the mounting holes up to these two bolts and tighten in place. The "distance" of spacing that I see between the headlight and the faring is such "the same distance" as the "thickness" of these two rubber grommets and flat washers, so with that said, I have to agree with Ragotp69gs in that the rubber grommets and flat washers MUST be missing. The only way to verify this is to remove the outer /front fairing and visually look to see if the two rubber grommets and washers are behind the headlight bracket assembly. One can not see these if the fairing has not been removed. Oh and I also agree nothing is bent Link to comment Share on other sites More sharing options...
Stealthblade Posted May 31, 2015 Share #5 Posted May 31, 2015 I have my fairing split and the headlight out, so I just took a pic of the grommets in question. Link to comment Share on other sites More sharing options...
ragtop69gs Posted June 1, 2015 Share #6 Posted June 1, 2015 Thanks Eck, that's what I was getting at. The picture is the grommets I refer to and must have the shouldered washer to everything aligned and spaced correctly. Link to comment Share on other sites More sharing options...
Brake Pad Posted June 1, 2015 Author Share #7 Posted June 1, 2015 (edited) Okay were going to split the faring and then send more pictures anything you guys can do for help is most appreciated Star Rider thanks everyone for this help, star rider and his wife are another couple from VR.org visiting for a few days. Edited June 1, 2015 by Brake Pad Link to comment Share on other sites More sharing options...
Stealthblade Posted June 1, 2015 Share #8 Posted June 1, 2015 You can maybe hit a hardware store for something close to the grommet, and possibly the shoulder washer. 2 rubber washers and a flat washer could work, just not as stable. Let me know if you need measurements or more pics of them. Bob Link to comment Share on other sites More sharing options...
Eck Posted June 1, 2015 Share #9 Posted June 1, 2015 You can maybe hit a hardware store for something close to the grommet, and possibly the shoulder washer. 2 rubber washers and a flat washer could work, just not as stable. Check these out at Lowes if you need replacement bushings: The Hillman Group Rubber Bushing - Item #: 315636 | Model #: 884620 - $1.44 ea Link to comment Share on other sites More sharing options...
djh3 Posted June 1, 2015 Share #10 Posted June 1, 2015 Mike the entire headlight assembly is on a tube frame deal in there. Could it be it got pushed back? I can take mine apart and get some dimensions from something not movable, say the triple tree or something. Link to comment Share on other sites More sharing options...
Royalstargazer Posted June 1, 2015 Share #11 Posted June 1, 2015 If I remember correctly, there are two plastic alignment pins molded into the inside of the fairing cover that align with two rubber grommets above the headlight assembly. Maybe when you installed the fairing they were not aligned and being held out? Link to comment Share on other sites More sharing options...
STAR RIDER Posted June 1, 2015 Share #12 Posted June 1, 2015 (edited) Thanks Mike for posting my problem with the venture. I just got home from your house and took the fairing off, here is what I have. It does not look like the picture shown in the posting above. Edited June 1, 2015 by STAR RIDER Adding More Pictures Link to comment Share on other sites More sharing options...
STAR RIDER Posted June 1, 2015 Share #13 Posted June 1, 2015 I think I found something that would push the Headlight forward inside the fairing. But I will need help to make sure if the ball rides on the outside of the tab or inside. I found the ball inside the tab when I took the bracket apart. If the ball rides on the outside of the tab, this would push the headlight forward. Does anyone know on there venture what it looks like??? Link to comment Share on other sites More sharing options...
Stealthblade Posted June 1, 2015 Share #14 Posted June 1, 2015 I have a couple more pics of my lamp Looks like yours sets farther into the bracket than mine does If you need any more pics, or measurements, let me know. Link to comment Share on other sites More sharing options...
mrsteve Posted June 2, 2015 Share #15 Posted June 2, 2015 Gary, I'm no expert but that ball looks like part of the headlight adjuster and in stealthblades pics it is inside the piece on the bracket. His also has some kind of grommet or washer on the ball shaft. Could yours have come off or otherwise moved? If the ball shaft is adjustable is it all the way in or out? Link to comment Share on other sites More sharing options...
STAR RIDER Posted June 2, 2015 Share #16 Posted June 2, 2015 I removed the tab that holds the ball shaft and seen it was cracked. This hold the headlight assembly forward. The ball sits in a grove inside the tab. "NOW" were do I gat one of these? see pictures attached Link to comment Share on other sites More sharing options...
mrsteve Posted June 3, 2015 Share #17 Posted June 3, 2015 Two part epoxy? Link to comment Share on other sites More sharing options...
STAR RIDER Posted June 3, 2015 Share #18 Posted June 3, 2015 Seems like you have to buy the whole assembly. might have to use the epoxy for a quick fix like you said. Thanks Link to comment Share on other sites More sharing options...
ragtop69gs Posted June 3, 2015 Share #19 Posted June 3, 2015 Call Pinwall cycle parts. Link to comment Share on other sites More sharing options...
STAR RIDER Posted June 3, 2015 Share #20 Posted June 3, 2015 I checked with Pinwall Cycle Parts and I would have to purchase a used headlight assembly which would be costly for just a plastic insert for the headlight assembly. Link to comment Share on other sites More sharing options...
