Sailor Posted August 21, 2014 Share #1 Posted August 21, 2014 Bike just crapped out on me. The two left cylinders keep cutting in and out. I am supposed to lead the toy run on Saturday. No way to get it off the island to a shop. I have cleaned the air filters and I have a socket that fits the carbs but I don't have an extension that will fit the socket. I have poured in a can of Seafoam and am hoping for the best. Any other suggestions? Link to comment Share on other sites More sharing options...
kevin-vic-b.c. Posted August 21, 2014 Share #2 Posted August 21, 2014 Coils? Both at once would be odd. Fuel filter maybe? Link to comment Share on other sites More sharing options...
cowpuc Posted August 21, 2014 Share #3 Posted August 21, 2014 Try draining the float bowls (loosing the drain plugs on the carbs and letting them empty) than refill by turning the key on and off until the bowls refill.. May have picked up some water in your fuel... Link to comment Share on other sites More sharing options...
Sailor Posted August 22, 2014 Author Share #4 Posted August 22, 2014 It idles ok but then the revs change up and down. If I rev it up it backfires and the two left cylinders cut in and out. It seems to be associated with the revs. Link to comment Share on other sites More sharing options...
CMCOFFEY Posted August 22, 2014 Share #5 Posted August 22, 2014 Has the bike been sitting long? If so, was it stored on the side stand? My left side carbs were all but plugged up when I got my bike. My left side plugs were as black as black can be. Pull the tank and spray the carbs out. Link to comment Share on other sites More sharing options...
Neil86 Posted August 22, 2014 Share #6 Posted August 22, 2014 The left carbs share a carb bowl vent hose.....that runs forward and down in front of left air box in lowers. Ensure the hose and carb vent nozzles are clear. Link to comment Share on other sites More sharing options...
fishrepair Posted August 22, 2014 Share #7 Posted August 22, 2014 Seafoam, Seafoam, Seafoam, and then, more Seafoam:fingers-crossed-emo Link to comment Share on other sites More sharing options...
Sailor Posted August 22, 2014 Author Share #8 Posted August 22, 2014 Pulled the air filters and cleaned them. Running the bike every day. Drained fuel out of the tank..no sign of water?????? Letting the sea foam sit in there overnight and hoping it works. Link to comment Share on other sites More sharing options...
bongobobny Posted August 22, 2014 Share #9 Posted August 22, 2014 Listen to Neil 86, he knows... :bowdown::bowdown: Link to comment Share on other sites More sharing options...
dacheedah Posted August 22, 2014 Share #10 Posted August 22, 2014 I'd drain all the gas including carbs and throw the old in in a car. Can of seafoam 100% and give a soak overnight. Drain the seafoam, add fresh gas and refresh the plugs. Too many additives in the gas can cause issues also. With the gas refreshed you can test the fuel pump also. See if it runs better Link to comment Share on other sites More sharing options...
kevin-vic-b.c. Posted August 23, 2014 Share #11 Posted August 23, 2014 any luck yet Kerry? Link to comment Share on other sites More sharing options...
Sailor Posted August 23, 2014 Author Share #12 Posted August 23, 2014 Drained the carbs, checked fuel for water, put in a can of seafoam, sprayed the carbs with cleaner. Have got it from two cylinders to three and sometimes four. I noticed lots of fuel seeming to come from the left two carbs. Going to let it sit tonight then try again in the morning. Running out of time. Link to comment Share on other sites More sharing options...
Sailor Posted August 23, 2014 Author Share #13 Posted August 23, 2014 I have noticed that it runs on all four if the throttle is just right. It cuts out soon as I try to get it up a hill. Link to comment Share on other sites More sharing options...
kevin-vic-b.c. Posted August 23, 2014 Share #14 Posted August 23, 2014 I am hoping Santa makes his rounds today Link to comment Share on other sites More sharing options...
Woody Posted August 23, 2014 Share #15 Posted August 23, 2014 do as Neil86 said and then drive it like you stole it. Link to comment Share on other sites More sharing options...
Sailor Posted August 23, 2014 Author Share #16 Posted August 23, 2014 Worked on it again and all I could get was three cylinders and sometimes four if the revs were just right. Gave up and led the run in my 47 chev pickup rat rod. It worked out well. One of the original organizers has cancer so she could not ride but she got to make one last run in the pickup. Link to comment Share on other sites More sharing options...
