FROG MAN Posted February 26, 2008 Share #1 Posted February 26, 2008 Momamo's 99 has a cracked cowling and very bad scuffs behind the barons sticker. Inside the whole right side plastic tabs are gone so nothing to hold the screws in place. I have the right side secure with plastic wire ties. I'm not going to pay $450 for a new one so what are my options? I seen a used one sell on Ebay for $75 one time but probably never again. Maybe it's time for a beer 30 cowling hooter. Anybody any good at plastic repair. Getting close to paint time. Link to comment Share on other sites More sharing options...
RoadKill Posted February 26, 2008 Share #2 Posted February 26, 2008 Momamo's 99 has a cracked cowling and very bad scuffs behind the barons sticker. Inside the whole right side plastic tabs are gone so nothing to hold the screws in place. I have the right side secure with plastic wire ties. I'm not going to pay $450 for a new one so what are my options? I seen a used one sell on Ebay for $75 one time but probably never again. Maybe it's time for a beer 30 cowling hooter. Anybody any good at plastic repair. Getting close to paint time. I think you should buy her a shiny new one! Link to comment Share on other sites More sharing options...
FROG MAN Posted February 26, 2008 Author Share #3 Posted February 26, 2008 Thanks roadkill. Venture friends sure like to spend other peoples money.:rotf: Link to comment Share on other sites More sharing options...
Marcarl Posted February 26, 2008 Share #4 Posted February 26, 2008 Either use plastex, or grind up some ABS pipe, mix it with Acetone and build your new stuff as necessary. Link to comment Share on other sites More sharing options...
Eck Posted February 26, 2008 Share #5 Posted February 26, 2008 I seen a used one sell on Ebay for $75 one time but probably never again. Frog man, I just saw a 2nd gen, liquid silver fairing on ebay this morning for $75.00 that had a couple minor scratches on the right side by the eyebrow.. Im trying to locate it again and if I find it I will send you the link.. found it...its up to $81.00 right now. http://cgi.ebay.com/ebaymotors/YAMAHA-ROYAL-STAR-VENTURE-XVZ-FAIRING_W0QQcmdZViewItemQQcategoryZ35560QQihZ012QQitemZ220203796238QQrdZ1QQsspagenameZWDVW Link to comment Share on other sites More sharing options...
Mariner Fan Posted February 26, 2008 Share #6 Posted February 26, 2008 I saw that one too. I see these on E-Bay every once in awhile. Link to comment Share on other sites More sharing options...
FROG MAN Posted February 26, 2008 Author Share #7 Posted February 26, 2008 Thanks Eck. That one looks good. I scheduled a snipe bid we will see what happens. Link to comment Share on other sites More sharing options...
Eck Posted February 26, 2008 Share #8 Posted February 26, 2008 Thanks Eck. That one looks good. I scheduled a snipe bid we will see what happens. Your welcome Frogman, Hey, if you do get the one off ebay, you could also try to fix the old one for a spare by possibly making a plastic repair using this method: http://wiki.vfrworld.com/index.php/Plastic_Repair Link to comment Share on other sites More sharing options...
FROG MAN Posted February 26, 2008 Author Share #9 Posted February 26, 2008 Yea that was my thoughts. Momamo wants to get started on the paint soon. I can play with plastic repair later. Have you guys talked her out of PINK yet? Link to comment Share on other sites More sharing options...
Yammer Dan Posted February 26, 2008 Share #10 Posted February 26, 2008 Guy just down the road from you don't do to bad on that stuff. He may start to get some time off from work soon... Link to comment Share on other sites More sharing options...
FROG MAN Posted February 26, 2008 Author Share #11 Posted February 26, 2008 When he gets a garage I might send him some business. Need to get a 83 running first. Link to comment Share on other sites More sharing options...
venturejockey Posted February 26, 2008 Share #12 Posted February 26, 2008 If you want to do the plastic solvent repair route. Go to Lowes and buy a can of ABS solvent (it has a blue label) clean the crack with acetone or MEK then lay some of that fiberglass mesh that is used for joining sheet rock together over the cleaned body part then start laying up layers of the solvent. The repair will become a fiberglass reinforced solid layer of ABS. Easy to do just takes a while for thick layers of the solvent to get fully hard. Link to comment Share on other sites More sharing options...
86er Posted February 27, 2008 Share #13 Posted February 27, 2008 Another way is to use Devcon PlasticWelder (a two part epoxy) combined with fiberglass cloth. That worked very well when I was repairing the 86 after the Dragon slew it! Link to comment Share on other sites More sharing options...
hipshot Posted February 27, 2008 Share #14 Posted February 27, 2008 If you want to do the plastic solvent repair route. Go to Lowes and buy a can of ABS solvent (it has a blue label) clean the crack with acetone or MEK then lay some of that fiberglass mesh that is used for joining sheet rock together over the cleaned body part then start laying up layers of the solvent. The repair will become a fiberglass reinforced solid layer of ABS. Easy to do just takes a while for thick layers of the solvent to get fully hard. o.k. folks. from my recent , repairs, i have found that the "abs plastic glue" from lowes, doesn't work nearly as well as the "home-made" version. for some reason, the abs glue in a can, is VERY porous, meaning ,lots of air bubbles.the home-made variety, seems to turn out a LOT better. remember, before you start a fairing repair,WAX THE PAINTED SIDE!!!! that way, any "over application", that seeps through, is easily removed with a PLASTIC putty knife. only leaves a hairline black mark.no repainting necessary. just jt Link to comment Share on other sites More sharing options...
Rick Butler Posted February 27, 2008 Share #15 Posted February 27, 2008 Gerald, I have at least 4 good front cowlings (one 99 2 tone gray) in my attic most with small scatches but none that would not be fixed by a new paint job. I'd let you have it for a good price, especially since you made her buy her own right bag. Rick Link to comment Share on other sites More sharing options...
FROG MAN Posted February 27, 2008 Author Share #16 Posted February 27, 2008 :rotf::rotf: Rick I paid for 99.9 % of that scoot. @#!^ if she wasn't gonna paint it PINK she might get another .1% out of me. Besides I'm enjoying this. Ladies get a better price for parts. In her eyes it's still 50/50.:rotf: Link to comment Share on other sites More sharing options...
venturejockey Posted February 27, 2008 Share #17 Posted February 27, 2008 o.k. folks. from my recent , repairs, i have found that the "abs plastic glue" from lowes, doesn't work nearly as well as the "home-made" version. for some reason, the abs glue in a can, is VERY porous, meaning ,lots of air bubbles.the home-made variety, seems to turn out a LOT better. remember, before you start a fairing repair,WAX THE PAINTED SIDE!!!! that way, any "over application", that seeps through, is easily removed with a PLASTIC putty knife. only leaves a hairline black mark.no repainting necessary. just jt This wasn't my experience but I was just trying to reinforce a crack and fill a hole. Link to comment Share on other sites More sharing options...
MamaMo Posted February 27, 2008 Share #18 Posted February 27, 2008 (:rotf::rotf: Rick I paid for 99.9 % of that scoot. @#!^ if she wasn't gonna paint it PINK she might get another .1% out of me. Besides I'm enjoying this. Ladies get a better price for parts. In her eyes it's still 50/50.:rotf: ) GERALDDDDDDDDDDD you are going to be in trouble. Keep up and it will be a Bright HOT PINK. Was considering being nice and just using Hot Pink Pinstriping. Black - Hot Pink , Teal-Purple-Hot Pink, Blue-Hot Pink, Purple-Hot Pink, etc. Oh the opinions. By the way has anyone bought paint off of ebay to paint their bike. What was the results? Link to comment Share on other sites More sharing options...
