labill Posted April 15, 2013 Share #1 Posted April 15, 2013 Just attached side car to my 2000 Venture. Needless to say power and fuel went down. Been told to change to V Max rear and pickup about 500 rpm. Has anyone increased HP in the engine? Looking for ideas. Thanks Labill Link to comment Share on other sites More sharing options...
Squidley Posted April 15, 2013 Share #2 Posted April 15, 2013 Bill, The Vmax gears will absolutely help with more umph, it will raise your rpms in 5th gear about 500 rpms at same cruising speed. Another thing you might consider is going with a Dyna 3000 ignition kit on your bike. You can change the timing curve of the engine and raise the rev limited as well. These 2 things will give you more useable power. Your fuel consumption is unfortunately not going to change a whole lot. Make absolutely sure that your carb floats are set properly and that the carbs are synced right. This will help with your fuel consumption. Link to comment Share on other sites More sharing options...
labill Posted April 15, 2013 Author Share #3 Posted April 15, 2013 Squid key, That's where I start then. Fuel I will have to live with. Thanks again Link to comment Share on other sites More sharing options...
labill Posted April 15, 2013 Author Share #4 Posted April 15, 2013 Squidley, Sorry Link to comment Share on other sites More sharing options...
sanderjack Posted April 15, 2013 Share #5 Posted April 15, 2013 I have been thinking of putting a sidecar on my 2009 RSV so that my boxer can ride with us. What did you get and how hard was it to attach. Link to comment Share on other sites More sharing options...
labill Posted April 15, 2013 Author Share #6 Posted April 15, 2013 Steve, Purchased a Formular II from Motorvation in Sibley, IA. They attached without any problems. I took the sidecar brake. That way I can remove the sidecar without getting air in brakes. Plus the individual brake makes right turns easy. I did not extend the front end but getting use to it. Electric lean a must. Mary at Motorvation is super to deal with and sidecar quality is excellent Link to comment Share on other sites More sharing options...
Cougar Posted April 15, 2013 Share #7 Posted April 15, 2013 Pictures Please:confused24: Link to comment Share on other sites More sharing options...
dacheedah Posted April 15, 2013 Share #8 Posted April 15, 2013 Pictures Please:confused24: or as we say pitures Link to comment Share on other sites More sharing options...
labill Posted April 15, 2013 Author Share #9 Posted April 15, 2013 Will be home in about a week and will post Link to comment Share on other sites More sharing options...
labill Posted September 9, 2013 Author Share #10 Posted September 9, 2013 [ATTACH]80050[/ATTACH] Late in posting. Hope it takes. Just had V-max rear installed. Pickup this week and will try. Link to comment Share on other sites More sharing options...
beltfed50 Posted September 10, 2013 Share #11 Posted September 10, 2013 I like that! Link to comment Share on other sites More sharing options...
