alwrmcusn Posted April 4, 2013 Posted April 4, 2013 Ok, now that we have a fix for the Hannigan trunk lock (and at a VERY reasonable price), I think we need a replacement for the clunky auxiliary gas tank cap. There are some really good fabricators on the website (I ain't one of 'em ).
Carbon_One Posted April 4, 2013 Posted April 4, 2013 I use a flip top style gas cap on my auxiliary tank builds. http://www.google.com/search?q=Flip+top+gas+caps&hl=en&qscrl=1&rlz=1T4GGNI_enUS464US464&tbm=isch&tbo=u&source=univ&sa=X&ei=aHtdUdeRNpS24AO-pIGYBA&ved=0CEsQsAQ&biw=1120&bih=524 How is the cap and fill neck attached on the Hannigan aux tanks? That info will determine which way to go in looking for an alternative cap. Pics would be helpful too. Research marine fill caps as well. Maybe you'll find a replaceable cap to your liking that way. Larry
bigbob Posted April 4, 2013 Posted April 4, 2013 Ok, now that we have a fix for the Hannigan trunk lock (and at a VERY reasonable price), I think we need a replacement for the clunky auxiliary gas tank cap. There are some really good fabricators on the website (I ain't one of 'em ). What he said. Did the trunk lock,next the gas cap. Bob
Cougar Posted April 4, 2013 Posted April 4, 2013 (edited) I have been very happy with Larry's Gas Cap. and it is PURRDY as well. I don't think I would see a problem of switching them out.. But I tell ya what I will stay out of this one not gunna end up like the trunk lock ordeal Did I ever tell you how much I love Carbon-One's AUX Tank? And the fill cap is on the correct side Edited April 4, 2013 by Cougar
alwrmcusn Posted April 4, 2013 Author Posted April 4, 2013 I use a flip top style gas cap on my auxiliary tank builds. http://www.google.com/search?q=Flip+top+gas+caps&hl=en&qscrl=1&rlz=1T4GGNI_enUS464US464&tbm=isch&tbo=u&source=univ&sa=X&ei=aHtdUdeRNpS24AO-pIGYBA&ved=0CEsQsAQ&biw=1120&bih=524 How is the cap and fill neck attached on the Hannigan aux tanks? That info will determine which way to go in looking for an alternative cap. Pics would be helpful too. Research marine fill caps as well. Maybe you'll find a replaceable cap to your liking that way. Larry Kowabunga Dude! I had NO IDEA there were that many varieties!! I do like your flip top. Will it fit? Don't know.
alwrmcusn Posted April 4, 2013 Author Posted April 4, 2013 And the fill cap is on the correct side Right on!! JMHO...all gas caps should be on the drivers side...left for bikes.
Carbon_One Posted April 5, 2013 Posted April 5, 2013 Anyone have a pic or know how the cap is attached on the Hannigan aux tank? If it's a normal sized 1 1/2" or 2" hose coupling the cap to the tank then its an easy swap for a flip top style cap Larry
TheKid Posted April 5, 2013 Posted April 5, 2013 Corbin_One, Are you going to adapt your tank to work with the new reverse hannigan has started to offer? Oh and when i was under one in daytona looking at the reverse the gas cap hooks to a small piece of hose that hooks to the tank. I would say a 1.5 or 2 in. I am not sure since i dont have one to double check size.
ragtop69gs Posted April 5, 2013 Posted April 5, 2013 Corbin_One, Are you going to adapt your tank to work with the new reverse hannigan has started to offer? Oh and when i was under one in daytona looking at the reverse the gas cap hooks to a small piece of hose that hooks to the tank. I would say a 1.5 or 2 in. I am not sure since i dont have one to double check size. If I may, There's no need to adapt Larry's tank, it will work with the Hannigan reverse setup.
Cougar Posted April 5, 2013 Posted April 5, 2013 I have his tank and I can install the reverse from Hannigan no new tank or mods from what Larry is saying. His tank is pretty much out of the way. Did I ever tell anybody how much I love his new aux tank system?
Carbon_One Posted April 5, 2013 Posted April 5, 2013 Kid my tank system will work with any of the Hannigan conversions and their optional equipment as the other guys are saying. I did have to cut off a small bracket on the left side of the frame on my bike thou. It was for mounting the fuel pump they use. I don't think all of the conversions have that bracket either. I know Ragtops didn't and as far as I know no one else has mentioned it having to be cut off . So I'm guessing only the newer conversions will have that bracket or maybe only those that requested an aux tank in their build sheet. Larry
alwrmcusn Posted April 5, 2013 Author Posted April 5, 2013 (edited) I don't know if these will help or not, but here they are. Edit addition: I just did a search for "SEADOG" and find that they are a supplier of marine equipment. This filler/cap is on the website and they may have a more useful screw-in cap. I'm going to be doing a closer look at their website. Edit addition: I think that basically the part I would need would be their item number 357090-1. It is a nylon cap with a pop-up to enable easier removal of the cap. They also come in different colors. However their website says Wholesale Only. http://i7.photobucket.com/albums/y282/alwrmc/Hannigan-Aux-Tank-Filler-1_zps1320323d.jpg http://i7.photobucket.com/albums/y282/alwrmc/Hannigan-Aux-Tank-Filler-2_zpsbca99ad4.jpg http://i7.photobucket.com/albums/y282/alwrmc/Hannigan-Aux-Tank-Filler-3_zps9b47229d.jpg http://i7.photobucket.com/albums/y282/alwrmc/Hannigan-Aux-Tank-Filler-4_zps934021f6.jpg Edited April 5, 2013 by alwrmcusn Additional info
ragtop69gs Posted April 5, 2013 Posted April 5, 2013 Al, The fuel fill we're using should work ok in place of what you pictured as long as the hose size is ok. I'm getting ready to install the new trunk latch, I sure hope all goes well. I have to open the hole to 1" and drill 2 mounting holes. I made the locking cam last night, just need to cut to length after lock is in. You can see pics of the lock in the "lock thread.
alwrmcusn Posted April 5, 2013 Author Posted April 5, 2013 I just ordered the Seadog part nr 357090-1 (the red cap) from Harbortown Marine 4765 Liberty Ave Vermilion, OH 44089 440-967-8072 $6.99 (cap) $7.50 S&H $14.50 Total Should be here in about 5-10 days. I'll repost if it fits and works ok. This should use the same installation but just replace the screw cap with a color coded one that has a pop up twist off feature. Seadog has a pop top filler that looks as though it would be an exact replacement but it's about $60.
ragtop69gs Posted April 5, 2013 Posted April 5, 2013 That should work just fine, certainly a cheaper alternative.
Carbon_One Posted April 5, 2013 Posted April 5, 2013 Yep that'll be a much cheaper alternative. The flip top caps I order are stainless steel and a bit pricey but IMO well worth the cost. A quality trike deserves a quality cap. Just my humble opinion here. Larry
alwrmcusn Posted May 1, 2013 Author Posted May 1, 2013 Just an addendum: That red cap with the flip up for turning the cap that I ordered. It did indeed look just like the chrome/stainless that is OEM on the Hannigan installation. It is not the same size and will not fit. It is much too small. It's now in my "junk" box.
HGWT Posted May 2, 2013 Posted May 2, 2013 I would like to put an auxillary tank on my Motor Trike conversion. Does anyone know of a tank that will fit my Motor Trike. Any pics of tanks where they are installed, size, dimensions, or anyone that can weld up/fabricate a custom tank. All help, constructive ideas, etc. is genuinely appreciated. I already have secured a fuel pump to utilized. I love my 2nd gen. and I love my trike conversion. I like the fit and finish of the Hannigan conversion better than the Motor Trike. The sad reality was I got the last Yamaha conversion done by Motor Trike and Hannigan was not building conversions at the time.
