Robby Posted February 1, 2013 Posted February 1, 2013 The bike shop I frequent sells and/or installs this stuff: http://www.ride-on.com/motorcycle-formula-mot.html The claim is it balances the rim and tire and automaticaly seals any punctures. They claim great results. Anybody use? I understand the sealing, how does it balance? $50 for both tires installed, not bad if prevents just one flat.
buddy Posted February 1, 2013 Posted February 1, 2013 (edited) Some will post on here that it does not work even tho they never used it..... For myself I like it! easy to install and never had any problems with the balance of the tires how it works is as you ride down the road it will spread around in the tire in the tread area and balances the tire as it moves never dries up nor damage the wheel at least it did for me but if you get a hole in the side wall you out of luck due to it staying in the tread area . Wildhair39 had it in his tires and while out on the road he replaced his rear tire due to it being worn out as he was everywhere!!!! and when they removed his tire they found 4 nails in the tire and he never lost any air during that time!!! I used it on three of my bikes and never had any issues.... Buddy Edited February 1, 2013 by buddy
Condor Posted February 1, 2013 Posted February 1, 2013 I ran it in the Avon front tire of the '83 and it worked great. Still haven't treated the '99 yet, but will. One item is the stuff will not balance a tire, but rather fine tune it. So you still need to get them balanced.
beltfed50 Posted February 1, 2013 Posted February 1, 2013 GOOD stuff! I was leery...had to replace rear tire for a nail this week; sealant slung out some (thought shock was going until close examination) but tire did not lose pressure. I had ridden on a PGR mission the day b4 I found it while checking pressures.
winston66 Posted February 2, 2013 Posted February 2, 2013 Winston66, Western Australia, I can not get the Ride on Tyre Sealant stuff over here, Can anyone tell me if the stuff that is known as Green Slime will do the same job and or is as good. As this is readily avaliable at most of the Automotive Parts stors that we have, Or is there another product that anyone would recommend. Cheers, Winston 66, Northampton, Western Australia
slowrollwv Posted February 2, 2013 Posted February 2, 2013 Winston I would not use the Green slime. That stuff is a PITA when you have to change the tire, And some places refuse to work on tires with it in them. It will not do a thing for the balance of the tire.
mraf Posted February 2, 2013 Posted February 2, 2013 I had some given to me way back at Potato Creek. Took it home and put it in the tires and did not feel any difference in the handing of the bike. When it was time to replace the tires the rims were not damaged at all and cleanup was easy. I ordered more for every new tire change since and have not had any problems. Knock on wood I haven't had any flats or picked up any objects to verify if it works or not. But for the few bucks it costs it is worth that for piece of mind. If it works like they boast. I believe Green Slime is not recommended for high speed tires and it does leave alot of slimy residue all over whatever rim you use it on.
Barrycuda Posted February 2, 2013 Posted February 2, 2013 Ride-On Works. Slime is CRAP! That seems to sum it up pretty tightly....
kevin-vic-b.c. Posted February 2, 2013 Posted February 2, 2013 Green slime is for emergency use only. I have a slime kit for when I am on a ride away from home just in case. I also have a plug kit I carry but slime if I need to slime
