Naked Rider Posted July 30, 2012 Posted July 30, 2012 It is VERY Hot around HERE in Missouri IT'S SO HOT ..... REALLY - HOW HOT IS IT ??? .....the birds have to use potholders to pull the worms out of the ground. .....the trees are whistling for the dogs. .....the best parking place is determined by shade instead of distance .....hot water comes from both taps. .....you can make sun tea instantly. .....you learn that a seat belt buckle makes a pretty good branding iron. .....the temperature drops below 90 F and you feel a little chilly. .....you discover that in July it only takes two fingers to steer your car. .....you discover that you can get sunburned through your car window. .....you actually burn your hand opening the car door. .....you break into a sweat the instant you step outside at 7:30 A.M. .....your biggest motorcycle wreck fear is, "What if I get knocked out and end up lying on the pavement and cook to death"? .....you realize that asphalt has a liquid stage. .....the potatoes cook underground, so all you have to do is pull one out and add butter. .....the cows are giving evaporated milk. .....farmers are feeding their chickens crushed ice to keep them from laying boiled eggs. IT'S SO DRY that the Baptists are starting to baptize by sprinkling, the Methodists are using wet-wipes, the Presbyterians are giving rain checks, and the Catholics are praying for the wine to turn back into water!
Yamamike Posted July 30, 2012 Posted July 30, 2012 "IT'S SO DRY that the Baptists are starting to baptize by sprinkling, the Methodists are using wet-wipes, the Presbyterians are giving rain checks, and the Catholics are praying for the wine to turn back into water!" :rotf:
Bubber Posted July 30, 2012 Posted July 30, 2012 It is so dry that when you spit it comes out steam and evaporates before it hits the ground !
etcswjoe Posted August 3, 2012 Posted August 3, 2012 It's so hot I saw a dog chassing a cat and they were both walking.
