etcswjoe Posted July 25, 2012 Share #1 Posted July 25, 2012 Well it looks like I am going to be sidelined at least 3 months or more so I am thinking I should do some serious maintenance on the bikes. So here is what I am thinking: Do the valve check, both bikes are way over due Check the clutches in both bikes maybe go ahead and upgrade the springs Check and adjust steering head bearings Change and Bleed Clutch and Brakes Flush cooling systems Check all the hoses and rubber Change oil in one just did the other Set the other one up to tow a trailer also Finish the solo mod on the one and paint it Lube everything that should be lubed. Any other ideas? Link to comment Share on other sites More sharing options...
Cougar Posted July 25, 2012 Share #2 Posted July 25, 2012 eat lots of ice cream and get better soon if there is something wrong with you. Link to comment Share on other sites More sharing options...
etcswjoe Posted July 25, 2012 Author Share #3 Posted July 25, 2012 eat lots of ice cream and get better soon if there is something wrong with you. Can't have the ice cream part of the reason I am in the shape I am. I had a small circulatory issue of my head that caused damage to the muscles and nerves in my left eye so I now have double vision doc says I may see improvement anywhere from 6 weeks to 3 months if it is not permanent. Link to comment Share on other sites More sharing options...
Black Owl Posted July 25, 2012 Share #4 Posted July 25, 2012 Did hell just freeze over???? A Navy Chief following someone elses orders. Link to comment Share on other sites More sharing options...
mm482 Posted July 25, 2012 Share #5 Posted July 25, 2012 Sorry to hear this Joe. Three months is a long time but you will make it. I was off the bike from January to April of this year, after having hip surgery. If I can make it you can too. It sounds like you have enough bike projects to keep you occupied for a while. Earl Link to comment Share on other sites More sharing options...
