bknsaddle Posted June 15, 2012 Share #1 Posted June 15, 2012 The hollow bolt in my passing light is broken. It's the one that screws into the turn signal from the passing light bucket. Had to do a roadside temporary repair while on a trip. Have searched, but have not found a source for these. Dealer is no help. Does anyone know a source or part number? Link to comment Share on other sites More sharing options...
Wizard765 Posted June 15, 2012 Share #2 Posted June 15, 2012 I think you may have to call a dealer. Are the passing lights part of the OEM stock bike or are they added on after? Link to comment Share on other sites More sharing options...
bknsaddle Posted June 15, 2012 Author Share #3 Posted June 15, 2012 They are OEM stock Yamaha Lights and the dealer said Yamaha did not list individual parts. Added: let me clarify: they are Yamaha Accessories mounted on a 2006 RSTD. Link to comment Share on other sites More sharing options...
Wizard765 Posted June 15, 2012 Share #4 Posted June 15, 2012 Do you have dimensions handy? What size bolt and how long? Is it visible when installed? Link to comment Share on other sites More sharing options...
bknsaddle Posted June 15, 2012 Author Share #5 Posted June 15, 2012 Assuming that the part numbers for the Passing Lamps are the same for the Venture and RSTD, STR-4XY35-1O-OO, the bolt is indicated as Item 9 on the attached parts list. No size is given. I will have to pull out the good one tonight to get size/tread/length..... Link to comment Share on other sites More sharing options...
bknsaddle Posted June 15, 2012 Author Share #6 Posted June 15, 2012 Sorry, PDF file was too large to upload. See http://www.venturerider.org/passinglamps/passinglamps.pdf Part is Item 9.... Link to comment Share on other sites More sharing options...
Wizard765 Posted June 15, 2012 Share #7 Posted June 15, 2012 Part number for the mounting hardware is STR-4XY35-40-00 I'm thinking we need the size of the bolt and maybe we can find someone with that bolt. Apparently they don't break it down to individual pieces for the mounting hardware.. "Special Bolt" :whistling:really does not tell us much in the instructions. Link to comment Share on other sites More sharing options...
bknsaddle Posted June 15, 2012 Author Share #8 Posted June 15, 2012 Yea, a little frustrating. I'll have to pull the good one apart tonight after work and take it up to the hardware store to try and figure out the size. I must admit I've never seen a bolt like it in any hardware store...... Link to comment Share on other sites More sharing options...
crowrod Posted June 15, 2012 Share #9 Posted June 15, 2012 any decent hardware should have lamp rod stock all it is is hollow all tread buy it in lengths and have have plenty to spare:backinmyday: Link to comment Share on other sites More sharing options...
PGunn Posted June 15, 2012 Share #10 Posted June 15, 2012 http://www.sidewalldistrodealer.com/p-1954-43-hardware-metric-hollow-stem-bolts.aspx http://www.universalcycles.com/shopping/product_details.php?id=44137&category=173 Link to comment Share on other sites More sharing options...
Flyinfool Posted June 15, 2012 Share #11 Posted June 15, 2012 All of the dimensional data for the bolt is here. http://www.venturerider.org/forum/showthread.php?t=41489 Link to comment Share on other sites More sharing options...
bknsaddle Posted June 15, 2012 Author Share #12 Posted June 15, 2012 PGunn and Flyinfool: Thanks for the info! Mine do not have a hex head. They have a tall metric bolt head....can't remember size at the moment. Not sure if that is the only difference (size/thread pitch/length) from the thread started by iquester for his '97............... Link to comment Share on other sites More sharing options...
PGunn Posted June 15, 2012 Share #13 Posted June 15, 2012 If it has a carriage bolt head you could get a piece of aluminum flat stock from Home Depot and stack the sizes, some to fit in the groove for the square on the bottom of the bolt head and one to compress them into place. Link to comment Share on other sites More sharing options...
aharbi Posted June 17, 2012 Share #14 Posted June 17, 2012 I should of kept my notes from when I had to replace one of mine. I too broke the hollow bolt for the passing lamp years ago when someone backed into my V-Star and knocked it over. The Venture uses the same bolt. Yamaha was no help - wanted me to buy the whole light bar! I'm lucky these folks a "just down the road" from me. I took the broken bolt and they matched it up for like $1.85. Give them a call, send them an email with a picture and the size. Great helpful folks. Austin Bolt Co. 2001 Rutland Drive Austin, TX 78758 (512) 836-1611 Link to comment Share on other sites More sharing options...
bknsaddle Posted June 18, 2012 Author Share #15 Posted June 18, 2012 Thanks Art. Will contact them today..... Link to comment Share on other sites More sharing options...
