soyer38301 Posted May 29, 2012 Share #1 Posted May 29, 2012 Since I just picked up this 85 Royale I have a question regarding the "intercom". The intercom shows on the audio controls but I do not see any plugs for it for the head gear. Is there any easy way to tap in, or for that matter to actually know if they bike is equipped with an intercom system? newbie thanks you Scott Link to comment Share on other sites More sharing options...
utadventure Posted May 29, 2012 Share #2 Posted May 29, 2012 The intercom is intergrated into the audio system. If you have the radio and amplifier, the intercom works with them. You have to have headsets in order for it to work and it's voice activated. The volume is controller by the main knob and the sensitivity is adjusted by the slider on the outside of the knob. Dave Link to comment Share on other sites More sharing options...
soyer38301 Posted May 29, 2012 Author Share #3 Posted May 29, 2012 The intercom is intergrated into the audio system. If you have the radio and amplifier, the intercom works with them. You have to have headsets in order for it to work and it's voice activated. The volume is controller by the main knob and the sensitivity is adjusted by the slider on the outside of the knob. Dave Don't have the headsets - didn't come with the bike so will have to get a set. But I guess my question would be better phrased -- where do they get plugged in? Link to comment Share on other sites More sharing options...
utadventure Posted May 29, 2012 Share #4 Posted May 29, 2012 If all of the original equipment is there.... the driver's helmet attaches to a 5-pin din plug that comes from the amplifier (under the radio/left fairing) up and is usually attached to the left side of the false tank cover. The passenger headset plugs into a box that is mounted to the lower front left side of the trunk. The box has a second plug (7-pin din I think) where a controller for the passenger also attaches. There is also a 5-pin din plug that runs to the amplifier under the passenger seat. Dave Link to comment Share on other sites More sharing options...
soyer38301 Posted May 29, 2012 Author Share #5 Posted May 29, 2012 Thanks. Looks like they have been removed then. I'll have to see about getting the parts to hook them back up. Nothing up front at all and have checked the back for the passenger and it just isn't there. Scott Link to comment Share on other sites More sharing options...
Prairiehammer Posted May 29, 2012 Share #6 Posted May 29, 2012 Here is the passenger controller: http://www.ebay.com/itm/Yamaha-Venture-Remote-Control-1986-1993-OEM-passenger-cb-remote-/230799289065?hash=item35bcb5aae9&item=230799289065&pt=Motorcycles_Parts_Accessories&vxp=mtr It snaps into this base mounted on the trunk: http://www.ebay.com/itm/1986-1993-Yamaha-Venture-Remote-Control-Base-Assembly-/300710183336?hash=item4603b941a8&item=300710183336&pt=Motorcycles_Parts_Accessories&vxp=mtr The driver's head set will plug into this female socket, usually located on a clip on the false tank cover, (at least that is so on 1986-1993): Link to comment Share on other sites More sharing options...
soyer38301 Posted May 29, 2012 Author Share #7 Posted May 29, 2012 Thank you Kevin. This gives me an idea on what I need to get and where it has to go. Appreciate it. Scott Link to comment Share on other sites More sharing options...
Marcarl Posted May 29, 2012 Share #8 Posted May 29, 2012 The 83,84, and 85's don't have a controller for the passenger, that was new thing in 86. Your 85 would just have a 5 pin wire going to the back where the passenger can plug in. It's a separate plug into the amplifier. Amplifier has 4 plug in's 1 driver, 2 passenger, 3 tape deck, 4 radio. The radio looks to be part and parcel with the amp, but if you look closely, they are 2 separate units tied together. Link to comment Share on other sites More sharing options...
Rocket Posted May 30, 2012 Share #9 Posted May 30, 2012 Thanks. Looks like they have been removed then. I'll have to see about getting the parts to hook them back up. Nothing up front at all and have checked the back for the passenger and it just isn't there. Scott An option that was probably was not ever installed... You need the install kit. http://www.sierra-mc.com/proddetail.asp?prod=JM-YV-41 The 83,84, and 85's don't have a controller for the passenger, that was new thing in 86. Your 85 would just have a 5 pin wire going to the back where the passenger can plug in. It's a separate plug into the amplifier. Amplifier has 4 plug in's 1 driver, 2 passenger, 3 tape deck, 4 radio. The radio looks to be part and parcel with the amp, but if you look closely, they are 2 separate units tied together. Link to comment Share on other sites More sharing options...
Dizzle223 Posted May 30, 2012 Share #10 Posted May 30, 2012 So if a guy had an 86 with the connector mounted on the false tank cover... what kind of head set would he want to purchase? Link to comment Share on other sites More sharing options...
Rocket Posted May 30, 2012 Share #11 Posted May 30, 2012 So if a guy had an 86 with the connector mounted on the false tank cover... what kind of head set would he want to purchase? There are a few to choose from, like EDsets, J&M, maybe a few other makes. With the J&M, you will need the 5 pin lower cord, to connect the headset itself to the interface cable & there are various models of headsets to choose from. Link to comment Share on other sites More sharing options...
Prairiehammer Posted May 30, 2012 Share #12 Posted May 30, 2012 Sorry, Scott. I failed to note that you had a 1985 bike, so my suggestions may not be applicable. Maybe could be made to work, though? Here's another that should be applicable to your bike, though. It's the cord from the amplifier to the false tank for the driver. It's NOS Yamaha and while I can't guarantee that you can get it for starting price... http://www.ebay.com/itm/Yamaha-Venture-NOS-accessory-lead-OEM-NEW-26H-88197-00-Venture-Royal-XVZ1300-/200768724351?hash=item2ebebf9d7f&item=200768724351&pt=Motorcycles_Parts_Accessories&vxp=mtr Link to comment Share on other sites More sharing options...
Rocket Posted May 30, 2012 Share #13 Posted May 30, 2012 Sorry, Scott. I failed to note that you had a 1985 bike, so my suggestions may not be applicable. Maybe could be made to work, though? Here's another that should be applicable to your bike, though. It's the cord from the amplifier to the false tank for the driver. It's NOS Yamaha and while I can't guarantee that you can get it for starting price... http://www.ebay.com/itm/Yamaha-Venture-NOS-accessory-lead-OEM-NEW-26H-88197-00-Venture-Royal-XVZ1300-/200768724351?hash=item2ebebf9d7f&item=200768724351&pt=Motorcycles_Parts_Accessories&vxp=mtr Yup, he could get only 1 cable for $??.?? + shipping, or the YV-41 install kit (both cables, noise filter, ect) for $51. + shipping. Link to comment Share on other sites More sharing options...
