GolfVenture Posted October 12, 2011 Share #1 Posted October 12, 2011 Ok so being that my New2Me 91 VR has only 6700 miles, I decided to drain the gas tank. Being that I had a heck of time doing that with my 89VR at the fuel filter, I decided it would be easier to do it at the Fuel Off/On switch on my 91VR. So I removed the hose clamp and then broke some of the seal from the rubber to the brass fitting, the hose would not come off. So I pried and pried at the hose until it finally came out. Well what came out was the brass fitting from the fuel Off/No switch. With some more digging the brass fitting finally broke loose from the hose. Well on the brass fitting there were some hose particles. Which means that I will need to clip off the end of the hose where the pieces of hose came off. I took some steel wool and got the rubber off the brass fitting. I drained the tank by using a 2 ft long fuel line and put it over the one end of the brass fitting and then gently placed the other end back into the fuel Off/On switch. Then drained the gas into the can. So now I need to get the brass fitting back into the Fuel Off/On switch. Now all the while draining the tank I only pushed and held the brass fitting into the Fuel switch and not a single drop of fuel leaked from the brass fitting. The brass fitting only went in a little bit and has more room to go into the fuel switch. My though is that I should be able to use some permatex gasket sealer (used on fuel sending units) and then press it all the way back into the fuel Off/On switch. So my question is, does my fix seem workable, or is there a better fix? Link to comment Share on other sites More sharing options...
Flyinfool Posted October 12, 2011 Share #2 Posted October 12, 2011 I never drained gas by any means other than riding. Look at the brass tube real close to see if maybe it was originally soldered into the fitting. If it was soldered in then I would solder it back in. The RTV may or may not hold it. It would be a real bummer to have it come out while riding and drain all that gas onto the exhaust pipe. If it was originally pressed in then you should be good with your plan. Do not try to solder on the tank unless you know what you are doing. An empty gas tank can be a BOMB when you apply heat if you do not get rid of the fumes correctly. Link to comment Share on other sites More sharing options...
GolfVenture Posted October 12, 2011 Author Share #3 Posted October 12, 2011 I don't normally drain the tank eithor, however I've read & heard that water settles to the bottom and when one rides on the normal tank and not reserve that the tank can rust from water at the bottom over the years. Well if others dont drain their tanks maybe I won't eithor. I do not see any solder on the brass tube and it will take some pressure to get it all the way in. Link to comment Share on other sites More sharing options...
Flyinfool Posted October 12, 2011 Share #4 Posted October 12, 2011 If you use SeaFoam regularly then there is no water in the bottom of your tank whether you run reserve or not. It is so hard to switch from main to reserve or back, that I leave it in reserve all of the time so that I do not have to worry about braking something while trying to turn the selector. I use a dose of Seafoam as recommended on the can every other tank if I am riding a lot or every tank if the bike is sitting long between runs. One of the properties of Seafoam is to absorb any water in the gas and send it on thru before it gets to be enough to cause a problem. Link to comment Share on other sites More sharing options...
VentureFar Posted March 23, 2016 Share #5 Posted March 23, 2016 Just did the same thing pulling the tank off my 07 2nd gen. Seems like pushing the tube back in with a tap tap tap is the way to go. Freaked me out seeing the brass tube come out so easily. Thanks all VentureFar... Link to comment Share on other sites More sharing options...
cowpuc Posted March 23, 2016 Share #6 Posted March 23, 2016 lol,,, just responded to ur other thread bother.. probably typing there while u were here.. Link to comment Share on other sites More sharing options...
Rmar Posted March 23, 2016 Share #7 Posted March 23, 2016 The Brass fitting is press in only no sealer. Tap it in snugly with a small hammer. Very Gently and it should be fine. Link to comment Share on other sites More sharing options...
GeorgeS Posted March 23, 2016 Share #8 Posted March 23, 2016 There are Filter Screens, inside, mounted on the Valve. To Repace the valve if that is necessary, you will have to ORDER All new parts. As I recall, there are 4 or 5 pieces, including the new screens that you will have to order. Includeing new gaskets, Take a look at the Parts Fitch, in the Yamaha parts manuel, so see how all the pieces go together. ( check any Yamaha dealer web site, you can pull up the parts listing to get all the part numbers ) Also good time to replace the rubber hose from the Petcock, across to the fuel filter. ( Rubber hose, might be getting rotten with age ) Link to comment Share on other sites More sharing options...
dave_wells Posted March 25, 2016 Share #9 Posted March 25, 2016 Thanks for the post . I read it a few days ago when I was rebuilding the petcock in the Venture. So today working on the RSTD the brass nipple pulled out. You guys all saved me from having an OH **** moment. I pushed it and gave it a little tap with a rubber mallet it it was fixed Glad to be a member. Link to comment Share on other sites More sharing options...
