Mr.G Posted September 22, 2011 Share #1 Posted September 22, 2011 I have heard that using the kickstand to shut the bike down is not the best option and that the kill switch is best. Any reason why? Thanks Link to comment Share on other sites More sharing options...
MiCarl Posted September 22, 2011 Share #2 Posted September 22, 2011 The reasoning is that by using the kill switch for routine shutdowns you develop the "muscle memory" to do it automatically in an emergency. Link to comment Share on other sites More sharing options...
dingy Posted September 22, 2011 Share #3 Posted September 22, 2011 I have heard that using the kickstand to shut the bike down is not the best option and that the kill switch is best. Any reason why? Thanks Kill switch cuts 12v+ power supply to TCI. Side Stand cuts 12v- power supply to TCI. There are other circuits that will permit 12v- path to TCI, such as Neutral switch. Either way motor stops. Turning key off would be overall best option, so bike is not left with key turned on. This is based on schematics located at http://www.venturerider.org/forum/showthread.php?t=42357 I have reasons to think these schematics are flawed in places, though an accurate reproduction of the Yamaha original. Some of the circuits shown are of concern, including the neutral switch circuit. Gary Link to comment Share on other sites More sharing options...
camos Posted September 23, 2011 Share #4 Posted September 23, 2011 Kill switch cuts 12v+ power supply to TCI. Side Stand cuts 12v- power supply to TCI. There are other circuits that will permit 12v- path to TCI, such as Neutral switch. Either way motor stops. Turning key off would be overall best option, so bike is not left with key turned on. Side Stand method not only stops motor but makes certain the transmission is left in gear. Often a good idea as I found out on top of the Beartooth this year. For as long as I can remember I had put the transmission into neutral before shutting off the motor. Not any more though, side stand down is now my only way of shutting down. The key is never left in the ignition, it's a habit since my house key is on the same ring. Link to comment Share on other sites More sharing options...
Yammer Dan Posted September 23, 2011 Share #5 Posted September 23, 2011 Just keep riding you don't have to shut it off!!!! Link to comment Share on other sites More sharing options...
camos Posted September 23, 2011 Share #6 Posted September 23, 2011 Just keep riding you don't have to shut it off!!!! What no more ICE CREAM? Well that's downright depressing. Link to comment Share on other sites More sharing options...
Mr.G Posted September 23, 2011 Author Share #7 Posted September 23, 2011 Thanks for the replies all. I always stop, drop the sidestand, turn off the key and lock the bars. Camos, you just use the ride through at DQ Link to comment Share on other sites More sharing options...
Flyinfool Posted September 23, 2011 Share #8 Posted September 23, 2011 Hmmmm.... I never tried to eat ice cream while riding..... The only time I park with the bike in gear is if I am parking on a hill that is steep enough for the side stand to slide backwards. NEVER park with the front pointed down the hill. I have seen vehicles still roll slowly down the hill, even when left in gear, slowly turning the engine over. All ringed engines leak compression over time. Link to comment Share on other sites More sharing options...
wannarsv Posted September 24, 2011 Share #9 Posted September 24, 2011 I always use the side stand to shut the bike off. I have seen guys pull up, shut the bike off, get to blabbing about something, then get off the bike only to realize they forgot to put the side stand down. Link to comment Share on other sites More sharing options...
