AKRefugee Posted August 27, 2011 Posted August 27, 2011 (edited) Fuel pump died yesterday so did a change out today. I went with the Mr. Gasket 42S model and the NAPA 3011 fuel filter. Was a very easy job and cost less than $60 total. WAY better than the $213 price I found on line. Only caveat I can give is to make sure you get the 90 degree, 45 Degree and the nipple and do not use the filter that comes with the pump. There is absolutely no way it will fit in there otherwise. Set it up like this picture I cut the line from the original pump and just connected it to the new wires just to keep it cleaned up. I also cut down the line from the filter to take the bend out and. I did not fasten down the new pump as it all tucked in fine just under the original mounting bracket. Edited August 28, 2011 by AKRefugee
eusa1 Posted August 28, 2011 Posted August 28, 2011 I've seen this picture posted on another site somewhere ????
TDunc Posted August 28, 2011 Posted August 28, 2011 Dang man, you using your good hand again on that keyboard?
TDunc Posted August 28, 2011 Posted August 28, 2011 Got it fixed he must be out riding... If he is, he had better called me first... sittin here ready to go!
warriorhoneybee Posted August 28, 2011 Posted August 28, 2011 what picture??? i'm fixing to do mine also,i went with the napa fuel pump a little lower volume.peace out
Yammer Dan Posted August 28, 2011 Posted August 28, 2011 Does that mean you will have a little less fuel when chasing those 1st Gens Mark???
GeorgeS Posted August 28, 2011 Posted August 28, 2011 Question: Is this fuel pump usable on a 1st Gen Bike ???
