EDGE1 Posted August 3, 2011 Share #1 Posted August 3, 2011 Hi Guys. Ive been through all the connectors on my ventures audio but still no sound , ive done the obvious made sure its on sp rather than hs . But still good , has anyone got any ideas before i try and source another unit ? Many Thanks Edge Link to comment Share on other sites More sharing options...
V7Goose Posted August 3, 2011 Share #2 Posted August 3, 2011 Make sure the CB is off. Make sure the volume is up. Try a headset to see if the problem is the speakers or speaker wires. Try different bands on the radio to see if it is radio related. Try the Aux input with an mp3 player. Try a cassette. Goose Link to comment Share on other sites More sharing options...
Freebird Posted August 3, 2011 Share #3 Posted August 3, 2011 All the same suggestions that I was about to make. Remember, the volume is separate for the CB and the Audio system. I would start by turning OFF the CB or adjusting the squelch all the way up to 20. You can turn the CB completely off by simply holding the CB button in for a few seconds. Link to comment Share on other sites More sharing options...
EDGE1 Posted August 3, 2011 Author Share #4 Posted August 3, 2011 Cheers Ill try all the different inputs . But mine is a uk spec bike and doesnt come with the C/B. Thanks again P.S its going to be a challange to find a Cassette LOL Link to comment Share on other sites More sharing options...
spear Posted August 4, 2011 Share #5 Posted August 4, 2011 Cassettes. You want cassettes? I got boxes of 'em. Converting 'em to MP3. Ah - the memories!!! Link to comment Share on other sites More sharing options...
wes0778 Posted August 4, 2011 Share #6 Posted August 4, 2011 This may be a dumb question (I'm good a those!!!) but have you confirmed that the speakers themselves are working? Sometimes it's the REALLY SIMPLE things that bite us in the butt when we over look them... Link to comment Share on other sites More sharing options...
EDGE1 Posted August 4, 2011 Author Share #7 Posted August 4, 2011 Is it likely all the speaker would stop working , or would it have the same effect if one failed ? Whats the best way to test the speakers . cheers Link to comment Share on other sites More sharing options...
V7Goose Posted August 4, 2011 Share #8 Posted August 4, 2011 Is it likely all the speaker would stop working , or would it have the same effect if one failed ? Whats the best way to test the speakers . cheers The best way to test the speakers is to use a headset - if the headset works, then the problem is in the speakers, not the radio/amp. If you don't have one, find someone with a wing (same basic cord) or an RSV and ask them to plug it in long enough to see if there is sound (but do not forget to switch the system from SP to HS!). Goose Link to comment Share on other sites More sharing options...
RedRider Posted August 4, 2011 Share #9 Posted August 4, 2011 The best way to test the speakers is to use a headset - if the headset works, then the problem is in the speakers, not the radio/amp. If you don't have one, find someone with a wing (same basic cord) or an RSV and ask them to plug it in long enough to see if there is sound (but do not forget to switch the system from SP to HS!). Goose AHHAAA, Watson, you may have something here. EDGE, check to see if the control is on HS or SP. You may have the controls set for headset, hence, nothing coming out the speakers. Center (or right since you don't have the CB) button. Should be the first option that comes up. Up or down arrow to select. Hope this fixes it. Cheap and easy. RR Link to comment Share on other sites More sharing options...
