22lyons Posted April 25, 2011 #1 Posted April 25, 2011 bought a 2000 venture last fall and got a chance to get out with the wife to ride. she told me that the backrest seemed to vibrate a slight bit that was irritating. she said the 82 goldwing didn't do that so wondering if something may be wrong. thanks larry
straycatt Posted April 25, 2011 #2 Posted April 25, 2011 I asked my Old Lady, and she said she's never noticed any vibration at all from the backrest. Maybe check the mounting bolts.
Owen Posted April 25, 2011 #3 Posted April 25, 2011 That's a new one on me... You don't notice it when you lean back? You humming real loud to the music? I got no clue...
Marcarl Posted April 25, 2011 #4 Posted April 25, 2011 What kind of mufflers have you got? Do you, or can you feel it?
22lyons Posted April 25, 2011 Author #5 Posted April 25, 2011 Marcarl said: What kind of mufflers have you got? Do you, or can you feel it? not sure what mufflers but they are louder. i can't feel anything. I did remove the trunk in the fall to lube the rear/end drive shaft etc.
Midrsv Posted April 26, 2011 #6 Posted April 26, 2011 My wife complained of the vibration if I was slightly lugging the engine. Say you are running 50 to 55 mph and come to a grade and as the throttle rolls on there will be more of a vibration and it really shows up in the backrest. She would feel it before me and she would let me know when to downshift. Most anytime below 60 to 65 under acceleration she would feel it. Just try dropping down a gear when it happens. Dennis
Sleeperhawk Posted April 26, 2011 #7 Posted April 26, 2011 22lyons said: not sure what mufflers but they are louder. i can't feel anything. I did remove the trunk in the fall to lube the rear/end drive shaft etc. Ummm, you do not need to remove the trunk to lube the rear end, grease the splines and replace tire. But onto your problem, when is the last you synced the carbs, because my passenger will feel vibrations before I do. Usually syncing gets rid of the vibration. Another, when the rear wheel was replaced, was it balanced? and another, is your rear tire pressure correct? I know others will have ideas too.
22lyons Posted April 26, 2011 Author #8 Posted April 26, 2011 Sleeperhawk said: Ummm, you do not need to remove the trunk to lube the rear end, grease the splines and replace tire. But onto your problem, when is the last you synced the carbs, because my passenger will feel vibrations before I do. Usually syncing gets rid of the vibration. Another, when the rear wheel was replaced, was it balanced? and another, is your rear tire pressure correct? I know others will have ideas too. 1. wiring/lighting too 2. not sure when synched good idea 3. tire supposed to be balanced by dealer when replaced 4. pressure is good
22lyons Posted April 26, 2011 Author #9 Posted April 26, 2011 Midrsv said: My wife complained of the vibration if I was slightly lugging the engine. Say you are running 50 to 55 mph and come to a grade and as the throttle rolls on there will be more of a vibration and it really shows up in the backrest. She would feel it before me and she would let me know when to downshift. Most anytime below 60 to 65 under acceleration she would feel it. Just try dropping down a gear when it happens. Dennis Good thought. I am not one who tends to lug; however, we were taking back country roads. I will have her think about this when at lower rpm's!
CaptainJoe Posted April 26, 2011 #10 Posted April 26, 2011 (edited) 22lyons, Let me know when you figure this out, as, I personally know some bikers, that would pay good money for 'vibration" nformation like this... Edited April 26, 2011 by CaptainJoe
Reddog170 Posted April 26, 2011 #11 Posted April 26, 2011 captainjoe said: 22lyons, Let me know when you figure this out, as, I personally know some bikers, that would pay good money for information like this... They may pay good money but we get it, and more, for a mere $12 a year. Shaun
BEER30 Posted April 26, 2011 #12 Posted April 26, 2011 Has the rear suspension been altered. How much air in the rear shock? I just replaced the rear tire, plus I adjusted the air in both front and rear shocks this evening and noticed a much smoother ride home. Is your wife petite? The empty space under the back rest caused my wife to be a little bit uncomfortable on long rides. She will sometimes place a small jacket/sweater in the empty spot for lower lumbar support as well as added seat pad to raise her up some. BEER30
Reddog170 Posted April 26, 2011 #13 Posted April 26, 2011 That is a good point. My wife got one of those lumbar supports at a truck stop and said it made a world of difference for her. But she has back issues already. Shaun
22lyons Posted April 26, 2011 Author #14 Posted April 26, 2011 BEER30 said: Has the rear suspension been altered. How much air in the rear shock? I just replaced the rear tire, plus I adjusted the air in both front and rear shocks this evening and noticed a much smoother ride home. Is your wife petite? The empty space under the back rest caused my wife to be a little bit uncomfortable on long rides. She will sometimes place a small jacket/sweater in the empty spot for lower lumbar support as well as added seat pad to raise her up some. BEER30 my wife is petite so that might be a good thought. i did put on the new tire but the bike is new to us so she can't compare. Also, adjusting the rear shock pressure may be helpful. thanks.
