M61A1MECH Posted April 6, 2011 Share #1 Posted April 6, 2011 I am sure many of you have seen the filler panels that Harleys have between the rear fender and the saddle bags, most of the time they have tail lights, brake lights and of turn signals built in. Has anyone tried to do this on a Venture? I am looking at some leds ideas, but most of what I have found are single illumination (all leds on or off at the same time) strips or bars, nothing that you could use as both running and brake or running and turn signals. Just like to get a little more light back there to go along with my signal dymaics LED bar and my LED tail light. Thanks for any ideas. Link to comment Share on other sites More sharing options...
Guest Posted April 7, 2011 Share #2 Posted April 7, 2011 Steve, check out this link. http://www.chromeglow.com/catalog.asp?prodid=520657 I have my led strips back there wired with this piece to run as run/brake lights. Simple install. Looks like a Christmas tree now. Link to comment Share on other sites More sharing options...
lumberjack49 Posted April 7, 2011 Share #3 Posted April 7, 2011 its been awhile but i think one of our member was making and selling something like that Link to comment Share on other sites More sharing options...
JerryT Posted April 7, 2011 Share #4 Posted April 7, 2011 If you add a RTB controller I think you may get what you want. Change the blinkers out to led's and they will run on low power all the time for additional back lighting. If you want to add additional led lighting to the saddlebags or what ever, just wire them in with the turns. That will let them run all the time on low power, and either blink or brake with the turns. My suggestion for the RTB is the Kurakyn #4613 as this will work as a plug and play on the second gen RSV and extremely easy install. I added 2 - 24 lamp brake bars under my trunk with each wire to each side with the blinkers. They run on low power all the time, then blink / brake with the other lights. Easy install and lots of light. Link to comment Share on other sites More sharing options...
Thom Posted April 7, 2011 Share #5 Posted April 7, 2011 Steve, check out this link. http://www.chromeglow.com/catalog.asp?prodid=520657 I have my led strips back there wired with this piece to run as run/brake lights. Simple install. Looks like a Christmas tree now. Steve , I install about 10 pairs of these a show and they work great , I get them from Custom Dynamic for less then 5 bucks each . also check out the plazma rod form CD , pricy but better than led strips Link to comment Share on other sites More sharing options...
M61A1MECH Posted April 7, 2011 Author Share #6 Posted April 7, 2011 Thanks for the ideas, These are what I am looking at, I will need to fab a bracket that will attach to the side rails on the fender. http://www.iowa80.com/DirectionsWEB/client/images/l158522.jpg http://www.iowa80.com/DirectionsWEB/client/graphics/quickinfo_enlarge_btn.gif 11" RED EXTREME LED VERSA-LITE Item Number: 158522 Regular price: $52.99 DESCRIPTION: LEDs are spaced 1/2 inches apart to produce vibrant light displays forsafety and enhance visibility. LEDs are mounted on a PC board with ge;l-filled polycarbonate tubes to make these lights waterproof and shock/vibration resistant. Chrome trim. Can be used for inside or outside applicatons. Sold in pairs. Link to comment Share on other sites More sharing options...
Freebird Posted April 8, 2011 Share #7 Posted April 8, 2011 Diamond R Accessories makes a nice one also and comes with all you need to install it on the RSV. They are also a loyal supporter of VentureRider.org http://www.diamondraccessories.com/yamaha/proddisplay.php?name=15%60%60%20Slimline%20LED%20Lightbar Link to comment Share on other sites More sharing options...
BOO Posted April 8, 2011 Share #8 Posted April 8, 2011 Diamond R Accessories makes a nice one also and comes with all you need to install it on the RSV. They are also a loyal supporter of VentureRider.org http://www.diamondraccessories.com/yamaha/proddisplay.php?name=15%60%60%20Slimline%20LED%20Lightbar I don't have this one but I have seen it on some bikes and it's really bright. Nice light. BOO Link to comment Share on other sites More sharing options...
M61A1MECH Posted April 8, 2011 Author Share #9 Posted April 8, 2011 Freebird, I have one like that under the trunk, 15" is to long to fit nicely beside the saddle bags. Link to comment Share on other sites More sharing options...
Freebird Posted April 8, 2011 Share #10 Posted April 8, 2011 ahhh.....now I understand. I missed the picture that you posted that showed exactly what you were looking for. Yes, these would be too long. Sorry about that. Link to comment Share on other sites More sharing options...
M61A1MECH Posted December 7, 2011 Author Share #11 Posted December 7, 2011 but I think I like them. I decided to go with the 7 inch lights instead of the 11 inch ones. There are not many attach points on the side rails so I decided to use the shorter lights to keep the cantilever effect to a minimum because I only used one attach point. Right now the inside ones are set up as brake lights (red), the out board ones are set for turn signals (amber), as soon as the divider circuits arrive I set them up as dual intensity for running / brake / turn. Link to comment Share on other sites More sharing options...
