slick97spirit Posted February 18, 2011 Share #1 Posted February 18, 2011 Tools Explained DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light . Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh ****!' SKILL SAW: A portable cutting tool used to make studs too short. PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters. BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs. HACKSAW: One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race. TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes , trapping the jack handle firmly under the bumper. BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge. TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect. PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads. STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms. PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. HOSE CUTTER: A tool used to make hoses too short. HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit. UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use. SON-OF-A-B*^%H TOOL: (A personal favorite!) Any handy tool that you grab and throw across the garage while yelling 'Son of a B*^%H!' at the top of your lungs. It is also, most often, the next tool that you will need. Link to comment Share on other sites More sharing options...
Flyinfool Posted February 18, 2011 Share #2 Posted February 18, 2011 :crackup: Link to comment Share on other sites More sharing options...
BoomerCPO Posted February 18, 2011 Share #3 Posted February 18, 2011 SON-OF-A-B*^%H TOOL: (A personal favorite!) Any handy tool that you grab and throw across the garage while yelling 'Son of a B*^%H!' at the top of your lungs. It is also, most often, the next tool that you will need. Boomer....who sez he is a master at using this one. Link to comment Share on other sites More sharing options...
Yammer Dan Posted February 18, 2011 Share #4 Posted February 18, 2011 I got several of those... Link to comment Share on other sites More sharing options...
Iowawegian Posted February 18, 2011 Share #5 Posted February 18, 2011 :rotfl::rotfl::rotfl: OMG...that was too funny!!!!!!!!!!! That sounds like the hubby this week! Hubby came in the house 3 nights ago after working on a snowplow. Blood was running down his nose and into his mustache. All he told me with a nasaly tone is "the tractor won" 2 nights ago, he came in from the shop, blood running out of his finger. I know there was some kind of power saw involved. I just handed him band aides. The butterfly kind. Last night, he came in.....with hydrolic (spell?) oil all over the front and back of his brand new Dickies, blue denim work shirt. He wanted to know if bleach would "take that out". Now this is from a guy who can build/weld anything from scratch. He's had a hell of a week! Link to comment Share on other sites More sharing options...
SMSgt Posted February 19, 2011 Share #6 Posted February 19, 2011 Now you tell us of all his failures and want us to believe he can build and weld antyhing "from scratch". It's going to take more convincing than that. But you can keep trying. Link to comment Share on other sites More sharing options...
saddlebum Posted February 19, 2011 Share #7 Posted February 19, 2011 SON-OF-A-B*^%H TOOL: (A personal favorite!) Any handy tool that you grab and throw across the garage while yelling 'Son of a B*^%H!' at the top of your lungs. It is also, most often, the next tool that you will need. I keep several of them spread around the house garage and shop at work . I find when you need one you need it instantly. This way there always one readily at hand. Link to comment Share on other sites More sharing options...
oldgoat Posted February 19, 2011 Share #8 Posted February 19, 2011 i like the last tool. i recall the day i threw a tool like that right across the garage and into my dads brand new car battery sitting on the work bench. all because i tought i could use a screwdriver to pull the tire off of my bike and punched a nice hole in the inertube. there by wrecking my whole day not to mention the next 2 weeks of being grounded for the new battery Link to comment Share on other sites More sharing options...
bkuhr Posted February 19, 2011 Share #9 Posted February 19, 2011 TIRE SPOON: A tool to pop out of a half mounted tire, flying into the head, to much blood in the eyes to find the SON-OF-A-B*^%H TOOL. Just done it:crying: Link to comment Share on other sites More sharing options...
