etcswjoe Posted August 27, 2010 #1 Posted August 27, 2010 What is the size socket needed for the front axle?
Naked Rider Posted August 27, 2010 #2 Posted August 27, 2010 the axle is 18mm and the pinch bolt is a 8mm you can find out all the sizes in the tech thread and you can down load all the manuals that you will need it says for a 1999 but it is also for the same year bike you have good luck
etcswjoe Posted August 27, 2010 Author #3 Posted August 27, 2010 Naked Rider said: the axle is 18mm and the pinch bolt is a 8mm you can find out all the sizes in the tech thread and you can down load all the manuals that you will need it says for a 1999 but it is also for the same year bike you have good luck Thanks for the info, however I must not have a stock axle. A 7/8 SAE almost fits it so I am thinking 22mm. I must have missed the the sizes on the thread old age I guess. .
V7Goose Posted August 27, 2010 #4 Posted August 27, 2010 etcswjoe said: Thanks for the info, however I must not have a stock axle. A 7/8 SAE almost fits it so I am thinking 22mm. I must have missed the the sizes on the thread old age I guess. . The stock front axle in my 05 RSV is 22mm, and the pinch bolt is a 6mm hex key. Goose
etcswjoe Posted August 27, 2010 Author #6 Posted August 27, 2010 Thanks all. I will stop by on the way home tonight and get a 22MM socket.
Naked Rider Posted August 27, 2010 #7 Posted August 27, 2010 i was just going by what the manual said
etcswjoe Posted August 27, 2010 Author #8 Posted August 27, 2010 Naked Rider said: i was just going by what the manual said I appricate it. with an 11 year old bike you never know whats been changed.
N3FOL Posted August 27, 2010 #9 Posted August 27, 2010 It is just a matter of time for me to remove my front wheel to replace the tire. This thread serves as a good information for the size of the axle bolt. I think I have a 22mm bolt in my tool box . Ride Safe.
dingy Posted August 27, 2010 #10 Posted August 27, 2010 Naked Rider said: i was just going by what the manual said What you have refers to the diameter of the bolt shafts, not the nut socket size. It is useful if looking for a replacement fastener. Gary
