6m459 Posted April 28, 2010 Share #1 Posted April 28, 2010 Has anyone any experience with a unit like this on a first gen Venture? Could I retire my 26 y.o. dash board instruments en mass with one of these? Thanks, Brian H. Link to comment Share on other sites More sharing options...
friesman Posted April 28, 2010 Share #2 Posted April 28, 2010 (edited) It would be a nice solution, but I doubt that it would work, as there are too many connections like our mechanical speedo cable. The newer scoots are using electronic sensors to hook up things like the vapor to. BUT, that being said, if anyone finds a way to makeit work please post here, I would love to see the updated solution. Brian Edited April 28, 2010 by friesman Link to comment Share on other sites More sharing options...
warthogcrewchief Posted April 28, 2010 Share #3 Posted April 28, 2010 I've seen that Dakota Digital makes a mechanical to electric adapter for speedos and tachs. But I'm sure you have to use the adapter for their gauges. http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=510/category_id=518/home_id=-1/mode=prod/prd510.htm Link to comment Share on other sites More sharing options...
6m459 Posted April 29, 2010 Author Share #4 Posted April 29, 2010 As I understand things, the Venture's mechanical speedometer cable is not a problem and could be removed. The Vapor unit has its own speedo sensor that counts the rotation of the front wheel with a fork mounted sensor and a hub mounted magnet. If I made the switch, I would likely take the core of the old speedo cable out and leave the outer sheath in place. Brian H. Link to comment Share on other sites More sharing options...
RedRaptor22 Posted April 29, 2010 Share #5 Posted April 29, 2010 Thats actually a pretty common swap for the SV, they even make an SV specific kit that comes with a new temp sensor and speedo sensor. Any hall effect type sensor like the second gen's speedo sensor can be used for the swap, along with 4 small magnets. The most common way we do it is to make a small bracket to mount to the front brake caliper and epoxy magnets inside the brake rotor rivets "assuming you can space them 90 degrees apart that way". The rest could probably be done easy enough with some time, test light, solder and shrinkwrap. Link to comment Share on other sites More sharing options...
RedRaptor22 Posted April 29, 2010 Share #6 Posted April 29, 2010 This one should work, comes with hall effect sensor, temp sensor and a magnet kit. $129.95 http://www.trailtech.net/product8157.html Can add this for warning lights $49.95 http://www.trailtech.net/022-PDA.html Says it comes with 8 icons for the idiot lights but only 4 places for them, you could probably locate any additional ones you may want somewhere else....or modify the yamaha rhino dash kit with 6 lights to fit your needs. $99.95 http://www.trailtech.net/75-RH-01.html Could probably find that stuff cheaper on ebay or something. Link to comment Share on other sites More sharing options...
puppy Posted April 29, 2010 Share #7 Posted April 29, 2010 yes, it is cool. But then what would you do with all that space in that humongous dash? Link to comment Share on other sites More sharing options...
6m459 Posted April 30, 2010 Author Share #8 Posted April 30, 2010 All the pix of the TrailTech units are at almost 2:1 scaling. The units are half the size shown! From the owners manual pdf on their site on page 11 or so, it shows the actual size as 107.5mm x 59.5 mm. I am wondering if my old eyes are good enough these days to read one of these from the pilot's seat to the XVZ1x dashboard! I have printed some scaled down versions of pix of their Vapor unit and will try a mock up tonight on one of my bikes. yes, it is cool. But then what would you do with all that space in that humongous dash? Link to comment Share on other sites More sharing options...
bongobobny Posted April 30, 2010 Share #9 Posted April 30, 2010 Ya know, that would be a GREAT idea for a specialized GPS. Have the map superimposed on the Speedometer with all the other info like dash gauges... Link to comment Share on other sites More sharing options...
6m459 Posted May 2, 2010 Author Share #10 Posted May 2, 2010 I printed out an image of the Vapor unit at 1:1 scaling with the real thing as per the dimensions shown in the manual. I cut it out and placed it on the dash of my bike. I took this picture from about where the driver's head would be. (Maybe a bit low as I had to kill a reflection from a fluorescent over head.) http://i919.photobucket.com/albums/ad39/UxHamby/vehicles/bike3/ea612b9b.jpg I was worried that the little thing would disappear on that big dash and that I'd be unable to read the digits with my 54 y.o. eyes. Looks usable to me despite my misgivings. Brian H. Link to comment Share on other sites More sharing options...
6m459 Posted May 2, 2010 Author Share #11 Posted May 2, 2010 Those Dakota Digital units look nice but sure are pricey! Brian H. I've seen that Dakota Digital makes a mechanical to electric adapter for speedos and tachs. But I'm sure you have to use the adapter for their gauges. http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=510/category_id=518/home_id=-1/mode=prod/prd510.htm Link to comment Share on other sites More sharing options...
puppy Posted May 2, 2010 Share #12 Posted May 2, 2010 Hmm, now you got me thinking. What if we removed the stock instruments, put in one of these units to the side, and on the other side a nice gps unit? All mounted flush, maybe some blinker, and/or indicator lights. Then run some gauges, if space permitting for engine functions, not covered by this unit. Hmmmmmm, gotta get the graph paper, and some pencils out. Would be kind of cool, to have done, I would think. Link to comment Share on other sites More sharing options...
CrazyHorse Posted May 2, 2010 Share #13 Posted May 2, 2010 Ive been thinking bout this project for a couple years was wondering if I could adapt another motorcycle digital dash for these bikes. Link to comment Share on other sites More sharing options...
6m459 Posted May 2, 2010 Author Share #14 Posted May 2, 2010 (edited) LCD Screens dashboard into an old Renault Super 5 car. Car stopped : showing all functions. http://zcarcockpit.free.fr/EN_index.html Edited May 2, 2010 by 6m459 english website url instead of the french one Link to comment Share on other sites More sharing options...
RedRaptor22 Posted May 2, 2010 Share #15 Posted May 2, 2010 Ive been thinking bout this project for a couple years was wondering if I could adapt another motorcycle digital dash for these bikes. Should'nt be too hard if the donor uses a similar setup, I've seen guys put gsxr gauges on the Sv a few times despite having some different systems. For instance the rpms read double actual rpms and a speedo healer had to be used because the gsxr used 8 magnets for the speedo pickup instead of 4 so without the healer it read half the speed. The vmax gauges would be an obvious first choice for an alternative imo...granted its any smaller and cleaner. Link to comment Share on other sites More sharing options...
Condor Posted May 2, 2010 Share #16 Posted May 2, 2010 I bet if they design one of those gizmo's, with just the basics, to fit in the tape deck of a 2ndGen they might sell a few. Link to comment Share on other sites More sharing options...
timgray Posted May 3, 2010 Share #17 Posted May 3, 2010 Why not simply gut the panel and use automotive gauges? It would probably be cheaper and easier to get. Link to comment Share on other sites More sharing options...
