Lowered kick stand foot
cb1313
Cb in M/H. Sorry for my late reply. I used all my Wifi data card for last month.
The site that has a foot after you cut off the end is www.motorwerk.com . I just tried it and the site worked. Go to Kaw., then the Versys. I purchased the bike two weeks ago and have already lowered the front and rear. I purchased BOTH stand kits ... the large one dosn't really fit the Venture but the smaller foot will. It works on hard surfaces but not too sure on gravel.
Any questions plase ask....... Cb
It looks like you could drill and tap a couple of holes and add a larger foot to the bottom. Rod
That is what it looks like they did for the larger foot one.
It is the same small foot with a piece of 1/4 thick aluminum diamond plate screwed to the bottom.
Those are both made from all aluminum. I'm not sure if I want to lean 900+ lbs onto a clamped on piece of aluminum. It may be fine as is. That is just my initial thought.
