What year 1300? (86 - up)
What year 1200? (83-85)
The 1983 were quite different from the 84-85 electrically.
Gary
I do know of a few ppl that have put the 1300 engine in the 83-85 mk1 when the 2nd gear issue that the 83-85's were known for popped up. It was way easier to replace the engine (and probably cheaper) than fixing the blown 2nd gear. I dont know of any major issues, but if I remember the carbs are jetted a bit different, and bit different wiring and cruise control.
Brian
The exhaust from the MKI (83-85) are different from the MKII (86-93). The TCI is different on the '83 as well. I would not recommend putting a 1200 into a 1300 engine primarily for two reason:
the 1300 engines fixed two problems with the 1200 engines 1) the water pump and 2) the split washers that fail on the 2nd gear.
Hey Preacherman,
What trouble is your friend having with his bike? Unless there is a connecting rod hanging out the side of the block, most things wrong with the 1300 motor can be repaired with a lot less effort than trying to figure out how to put a 1200 motor in a 1300 bike. If you could give us a few more details, I may have some suggestions for you to make this problem easier. If it is something major, I have an extra 1300 motor complete here at the shop if that would help.:confused24:
Earl
I fitted a '86 1300 motor to my '83 1200. No problems. Just a straight change over. The 1300 had bigger carbs but I just put my 1200 carbs back in to save on cost and it made no difference to performance or fuel economy. The 1200 motor had overheated and cracked a cylinder so I replaced it with the 1300 to get around the 2nd gear problem before it happened.
Merry Christmas !
Jim O'D
Darwin, Australia.
