Grandpagak Posted August 23, 2009 Share #1 Posted August 23, 2009 if the water pump leaks after you stop the engine.. does that mean you need a new water pump? or can you get the parts to fix it? is it simple to fix? does any one have one to sell? Curious minds NEED to know.. :crying::bang head: thanx.. Link to comment Share on other sites More sharing options...
stardbog Posted August 23, 2009 Share #2 Posted August 23, 2009 Gary, it all depeng. if is gasket, then some liquid gaskets can cure leak, but if is housing crack, than i gues you gonna need new pump. Dont know where is pump on 1st gen's but somebody will chime in. Good Luck. Link to comment Share on other sites More sharing options...
Pegasus1300 Posted August 23, 2009 Share #3 Posted August 23, 2009 usually when your pump leaks there is a shaft seal that is going out. Yes you can repair it by putting in a new seal and they are still available from Yamaha. If you still have the plastic impeller now would be a good time to change to the metal one.I am sure there are tech articles on the site here to help you with this.Pumps are in the same place 1st or 2nd gen,right side of the engine. Link to comment Share on other sites More sharing options...
Grandpagak Posted August 23, 2009 Author Share #4 Posted August 23, 2009 thanx guys!! plan is to check it out tomorrow.. any and all advice is appreciated.. Link to comment Share on other sites More sharing options...
Black Owl Posted August 24, 2009 Share #5 Posted August 24, 2009 Hmmm. Project bike??? Link to comment Share on other sites More sharing options...
skydoc_17 Posted August 24, 2009 Share #6 Posted August 24, 2009 Hey Gary, I have seen some people just change the Mechanical Seal (ceramic seal) use the old gaskets and lucked out. If I was doing the job at my "little shop by the creek" for you this is what I would replace to make sure that you NEVER had to do it again! After all these parts are 26+ years old! 6SKU: 93306-00004-00 BEARING (B6000)1$11.59http://www.yamahasportsplaza.com/modules/oemparts/images/partsadd.gif7SKU: 93101-10090-00 .OIL SEAL1$3.33http://www.yamahasportsplaza.com/modules/oemparts/images/partsadd.gif8http://www.yamahasportsplaza.com/common/images/icoPartSuper.gif Loading... SKU: 11H-12438-00-00 SEAL, MECHANICAL1$13.41 9SKU: 93211-16591-00 .O-RING1$4.38http://www.yamahasportsplaza.com/modules/oemparts/images/partsadd.gif 14http://www.yamahasportsplaza.com/common/images/icoPartSuper.gif Loading... SKU: 26H-12449-00-00 GASKET, water pump1$4.72 If your Impller is plastic: 2SKU: 1FK-12450-00-00 .IMPELLER SHAFT ASSY1$37.98http://www.yamahasportsplaza.com/modules/oemparts/images/partsadd.gif And I would do this just so you don't have to go back in there ever again! 18SKU: 26H-12446-00-00 JOINT1$28.37http://www.yamahasportsplaza.com/modules/oemparts/images/partsadd.gif19http://www.yamahasportsplaza.com/common/images/icoPartSuper.gif Loading... SKU: 93210-27194-00 O-RING2$5.54 These prices are from South Seattle Motorsports, Flatout Motorsports's prices are cheaper and they are closer to you. If you go to your local Yamaha Dealer, plan on paying about 25% more for the parts. While you are there add the drain plug upgrade and you should be good for years to come! http://www.venturerider.org/classifieds/showproduct.php/product/1724/cat/6 Hope this helps, Earl Link to comment Share on other sites More sharing options...
frogmaster Posted August 24, 2009 Share #7 Posted August 24, 2009 Earl, Man O Man you sure know how to hook a guy up!!! Impressive skills (I'm not worthy). Link to comment Share on other sites More sharing options...
Squeeze Posted August 24, 2009 Share #8 Posted August 24, 2009 It's only me, but i would just buy a new Water Pump Assy from a 2007 Vmax and undo the black Paint. Why ?? Because i know of so much Guys which tried to go the cheaper Route and just replace the Parts as Skydoc said. Most of them ended up buying the whole Assembly afterwards and had the new Parts lying around in Closet forever. That's because you're breaking the Casing way to easy when you're not exactly know what your doing. Why buy a Vmax Water Pump ??? It's much cheaper than the VR Part .... Must be the different Paint or something like that. :bluesbrother: P.S. You'll need the Gasket and both O-Ring a the Knee. Link to comment Share on other sites More sharing options...
