ststvn9 Posted July 27, 2009 Posted July 27, 2009 Looking for some suggestions as to what might be causing my Virago to idle high, at or near 2,000 rpm's. Just recently started doing it.
Squeeze Posted July 27, 2009 Posted July 27, 2009 Look for Vacuum Leaks first. Use a flamable Spray, Brake Cleaner or something like that and carefully spray it around the Carb Boots between Carb and Intake as well as the Area where the Intake Manifolds meet the Cyl.-Head.
rod Posted July 27, 2009 Posted July 27, 2009 :sign yeah that:Also make sure the throttle is closing all the way. Rod
