screaming red Posted March 17, 2009 Posted March 17, 2009 Hi everyone. I have read some posts on this have tried many things? My front right signal will just flash slightly and rear will flash quickly. When I used my 4 way flashers back will blink correctly front will blink slightly. I have replaced both front and rear with what is suggested by the Yamaha. I also have cleaned out any corrosion and applied dialectric grease. Any help will be appreciated. Screaming Red
Venturous Randy Posted March 17, 2009 Posted March 17, 2009 (edited) Sounds like a ground problem to me. See which wire is ground and make sure it is good. RandyA Edited March 21, 2009 by Venturous Randy
screaming red Posted March 21, 2009 Author Posted March 21, 2009 Took my front dash off to look at the harness that runs from the running lights and found a green wire disconnected in the harness. Reconnected green wire gave the harness more slack and everything works now. Screaming Red:thumbsup: Sounds like a ground problem to me. See which wire is ground and make sure it good. RandyA
mraf Posted March 21, 2009 Posted March 21, 2009 WOW, Randya 8 min flat. I can't wait till I have a question. You the man!
GeorgeS Posted March 21, 2009 Posted March 21, 2009 As an Electrician, I never did trust those " green wires "
cowpuc Posted March 21, 2009 Posted March 21, 2009 As an Electrician, I never did trust those " green wires " LOL,, and as a person who has cut tons of grass with a little push mower I have never met a flywheel key that I would trust not to get a notch in so small that you couldnt even see it but its always enough to mess up the timing so the stupid, idiotiotic, piece of crap mower wont start no matter how many times you pull it - and ALWAYS with a neighbor watching!!! Xcellent job Randya!! 'Puc
