Guest Sponge Bob Posted August 4, 2007 Share #1 Posted August 4, 2007 Hey Guys: I would like to replace both my rear turn signals as well my front ones with LED's. I don't want to loose the 4 way flasher, what can I do to get this all together? Sponge Bob It's a dry heat!!!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
awsmsrv Posted August 4, 2007 Share #2 Posted August 4, 2007 Hey Guys: I would like to replace both my rear turn signals as well my front ones with LED's. I don't want to loose the 4 way flasher, what can I do to get this all together? Sponge Bob It's a dry heat!!!!!!!!!!!!!!!!! You'll just have to use load equalizers. Kinda defeats the purpose of the LEDs, however. That's assuming you want to use less current. Link to comment Share on other sites More sharing options...
Hawque Posted June 18, 2013 Share #3 Posted June 18, 2013 Hey Guys: I would like to replace both my rear turn signals as well my front ones with LED's. I don't want to loose the 4 way flasher, what can I do to get this all together? Sponge Bob I have LEDs front and back on my '02 and the 4 ways work fine. Lights flash a bit fast but they get the attention of drivers, so I left them alone. Using load equalizers defeats the whole purpose of going to LEDs as the voltage draw is back to what you had with the original bulbs. Now if I could only keep the rain out of the damn things. Hawque:301: Link to comment Share on other sites More sharing options...
djh3 Posted June 18, 2013 Share #4 Posted June 18, 2013 Yea the draw is back up but only on the signal side. Which is very momentary with the load equilizers. Did you use a replacement bulb or the high dollar panel things that go in the fixture? I had them in my rears but didnt care for the fast flash thing and the bulbs I put in the front didnt look as brite as the incandesents. There has been a couple write ups around about how to modify our flasher units so they will work with the LED and still retain the auto cancel feature. Link to comment Share on other sites More sharing options...
XV1100SE Posted June 18, 2013 Share #5 Posted June 18, 2013 Check out the thread I did on the Custom Dynamics run/turn/brake and 100 LED brake light http://www.venturerider.org/forum/showpost.php?p=619134&postcount=9 Link to comment Share on other sites More sharing options...
cruzin123 Posted June 19, 2013 Share #6 Posted June 19, 2013 I drilled a very small hole in the bottom of the rear housing of the front signal lights and that seems to keep everything drier. Being sealed caused moisture due to the heat of the bulb. I also use a dialectric grease on the base of the bulb to prevent moisture damage. Link to comment Share on other sites More sharing options...
eusa1 Posted June 19, 2013 Share #7 Posted June 19, 2013 anyone notice how old this thread is?? Link to comment Share on other sites More sharing options...
XV1100SE Posted June 19, 2013 Share #8 Posted June 19, 2013 anyone notice how old this thread is?? Yes... but it was reopened today. :-) Link to comment Share on other sites More sharing options...
