deorto Posted September 9, 2008 Share #1 Posted September 9, 2008 will the frontfroks off an 89 vr fit on an 84 vr i mean the intire front end will the brake line match up----thanks for all your help---dae Link to comment Share on other sites More sharing options...
Squidley Posted September 9, 2008 Share #2 Posted September 9, 2008 They are different, the calipers are different (not sure if they are mounted in the same holes) and the antidive system is different. As far as the lines I couldn't tell you, but I know some of the 1st genners will chime in and fill in the blanks Link to comment Share on other sites More sharing options...
bongobobny Posted September 9, 2008 Share #3 Posted September 9, 2008 Yup, if you swap out the entire front end you just bolt on the brake lines. You will also have to swap out your master cylander for both the front and rear as the calipers have a larger area and require more hydraulic pressure to effectively work. The biggest thing you can do to improve brake performance is to switch to stainless steel brake lines. Rick at Buckeye Performance can fix you up with brand new lines ready to go for around $400 and it's well worth it!! You have to use the newer calipers and rotors as they are a different size. The anti dive uses the brake light signal to fire the relay for the anti dive. Link to comment Share on other sites More sharing options...
deorto Posted September 9, 2008 Author Share #4 Posted September 9, 2008 was planning to swap out the front end and leave the rear the same -- i found a 89vr that has front end damage most of the faring is cracked but bike is in good shape --now i can put put my faring off my 84 but the coloring is defferent and i do not know about the head light??? Link to comment Share on other sites More sharing options...
Squeeze Posted September 13, 2008 Share #5 Posted September 13, 2008 The MKII(-86 to '93) is the better front End because of the improved Brakes at least. The Head Light Assembly from a MKI won't fit a MKII unless you exchange the whole Fairing Stay. Link to comment Share on other sites More sharing options...
