Results 1 to 11 of 11
Thread: Bearings for H/F Tag-Along
  1. #1
    Join Date
    Mar 2009
    Richland, MS
    MS
    Post Thanks / Like
    Default Bearings for H/F Tag-Along
    Ok, Getting ready to put a bunch of miles on the Tag-Along in the next few weeks, so time to get rid of the crappy Chinese bearings. They have probably 6000-7000 miles on them.
    I took the wheels off and removed the old bearings, only to find they look almost perfect. As mentioned in a post a good while back, the seals were still leaking, probably due to the lack of polishing of the sealing surface, on the axle, during manufacturing. This seems to not be a problem as both wheels were still completely full of grease. The Honda Moly was a lot more "liquid" than when I put it in there, but was evidently doing its' job, very well. Oh well, I have new Timken bearings, along with new seals, on order from Motion Industries, here in Jackson, MS. All should be here in the morning.
    Fore those interested;
    The bearing part # is 30205M (It is a cup and cone set) $18.15/Set
    The seal part # is 30 X 52 X 10 A-NBR $ 2.18/Each
    Gonna pick them up in the morning and go two blocks down and get a couple of pounds of dry ice.
    Oh and go by and pick up a new tube of Honda Moly from BigBoyinMS
    Growing old is Manditory, Growing up is OPTIONAL!!!
    1968 Yamaha DT-1
  2. #2
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Default
    Good info.
    I'm going to take this info with me just in case I should ever need a set of bearings on the road.
    Hmmmm....
    I wonder if it is realistic to polish up the seal surface on the axle to help keep the seals from wearing out to fast.
    I will be deciding for sure after my trip to Oberlin, but I am thinking of just making up a new axle with new hubs to use standard SAE size bearings that are available anywhere. At the same time I may add electric brakes to the trailer.
    There is a place in IL that I found with really good prices on the parts needed. R&P Carriage.
    Good excuse for another road trip.
    Jeff Borowski . . 88 Venture standard
    Sometimes the thoughts in my head get bored and go for a stroll out through my mouth. This is never a good thing.
  3. #3
    Join Date
    May 2010
    Tichborne, ON
    Canada
    Post Thanks / Like
    Default
    Don't want to hijack this thread...but can you get the smaller tires like on these trailers balanced?
    Mine almost bounces if I hit 70 mph.
    Some days its just not worth the effort to chew my way out of my straight Jacket!
    Steve H
  4. #4
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Default
    They can be but not all shops have the right adapter to put them on a machine. The station that I go to can only do it because I made them an adapter to put the little tires on their balancer. The old bubble type balancer should still work.
  5. #5
    Join Date
    Mar 2009
    Richland, MS
    MS
    Post Thanks / Like
    Default
    Quote Originally Posted by Trader View Post
    I put 3oz of Ride-On in mine and it "seems" to have smoothed the little wheels out.
    1968 Yamaha DT-1
  6. #6
    Join Date
    Sep 2011
    Kankakee Il
    Post Thanks / Like
    Default
    I would worry about the brakes on the trailer, I have read that most commercial manufacturers of motorcycle trailers recommend against them.
    Motorcycle trailers do not need brakes unless the weight exceeds 1500 pounds gross. If you install brakes on your motorcycle trailer, be sure the brakes do not brake harder than the motorcycle or the motorcycle may flip backwards over the trailer when the brakes are applied. The brakes must always be properly adjusted.
    I know you should do your braking before the turn, however I would be worried that in a turn you were forced to hit your brakes and the trailer would pull you out of your axis and basically redirect you into some hard object. I know without them the opposite is true, I mean push your rear. We respond every day to our rear tire pushing our bikes and have learned to react to that ( not that it wouldn't be holy shhhhh) . The pull would be something different that we do not normally react to.
  7. #7
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Default
    Quote Originally Posted by dacheedah View Post
    Yes everything would have to be properly adjusted that holds true for all of the trailers that I pull with my truck also. The pros and cons of trailer brakes has been discussed many times with the only conclusion being that some people love them and some hate them. That is why the companies that make the heavier trailers have brakes as an option.
    I have never heard of trailer braking causing the tow vehicle to do a back flip. The physics of the situation say that that is absolutely not possible.
    But back to the regularly scheduled thread..... I do not wish to debate the pros and cons of brakes again in this thread.
  8. #8
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Default
    Quote Originally Posted by wes0778 View Post
    I wonder if the ride on acts a little like Dyna Beads and sloshes around to do some balancing?
  9. #9
    Join Date
    May 2010
    Tichborne, ON
    Canada
    Post Thanks / Like
    Default
    Quote Originally Posted by Flyinfool View Post
    But back to the regularly scheduled thread..... .
    Yeah...what's the idea of hijacking this thread to talk about trailer brakes!
    Especially after I hijacked the thread to talk about balancing trailer tires!!!!!
    so.......what were we talking about?
    Steve H
  10. #10
    Join Date
    Aug 2006
    Near Iowa City,Iowa
    Post Thanks / Like
    Default
    Jeff , yes it does. works great.
  11. #11
    Join Date
    Aug 2006
    Flint
    Post Thanks / Like
    Default
    I beat the crap out of a couple of the bearing when I built my trailer so I took them to a bearing warehouse to replace them, they were metric of coarse not anything standard,
    but the counter person looked at them and said they were a higher quality the standard wheel bearings. FYI
Similar Threads
  1. How hot do your wheel bearings get?
    By straycatt in forum Trailer Talk
    Last Post: 06-15-2010, 07:28 PM
  2. fork bearings
    By emtdouggood in forum First Generation Venture Tech Talk
    Last Post: 04-07-2010, 04:38 PM
  3. purchase bearings
    By maxantin@live.com in forum Watering Hole
    Last Post: 04-22-2009, 05:48 AM
  4. Swing arm bearings?
    By yamahamer in forum Second Generation Venture Tech Talk
    Last Post: 12-28-2008, 12:37 PM
  5. Trailer Bearings
    By StarRider07 in forum Trailer Talk
    Last Post: 07-18-2008, 12:04 AM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
