loosebiker 12 Posted February 11 Share #1 Posted February 11 I blead my rear brakes on 2000 venture now the bleeder screw will not close. Has anyone had this problem? If anyone has dealt with this how did you fix it. Link to post Share on other sites
Marcarl 2,231 Posted February 11 Share #2 Posted February 11 I would think that maybe there would be a piece of dirt caught under the screw in the seat. Take the screw, it's actually a valve out, clean the seat with a brush, pump a bit of fluid out and try again. Just my take sitting here. Link to post Share on other sites
saddlebum 1,582 Posted February 11 Share #3 Posted February 11 Also check the threads for damage while you have it out being as the caliper is aluminum and the bleeder screw steal it is not uncommon for thread tear or balling to occur if the screw was difficult to back out and so the screw would not go back in properly. Link to post Share on other sites
luvmy40 857 Posted February 11 Share #4 Posted February 11 (edited) There is a repair for damaged threads in this situation. I've installed a couple on the old HD "Banana" calipers. It's a brass insert with a new bleeder valve. You drill and tap a larger hole and screw the two piece insert into the caliper. They used to available at any auto parts store. Edited February 11 by luvmy40 Link to post Share on other sites
luvmy40 857 Posted February 11 Share #5 Posted February 11 https://www.autozone.com/test-scan-and-specialty-tools/brake-tool/dorman-help-brake-bleeder-screw-repair-kit/83105_0_0?cmpid=PLA:US:EN:AD:NL:1000000:HRD:71700000043780883&gclid=Cj0KCQiAyJOBBhDCARIsAJG2h5dfpphtb3SX1k8feggu78uxTbQrL2rvILL6D2BKesSr18sqTXwshzUaAnUXEALw_wcB 1 Link to post Share on other sites
