GolfVenture Posted May 2, 2013 #1 Posted May 2, 2013 I read that you are supposed to use K&N Air Filter Spray before using them. Anyone use some other spray from a local auto parts store?
Peder_y2k Posted May 2, 2013 #3 Posted May 2, 2013 Liquid Wrench Chain Lube. -Pete, in Tacoma WA USA '83,88
Snaggletooth Posted May 2, 2013 #5 Posted May 2, 2013 WD-40 was designed for more for water dispersion than lubrication. Works great for drying out a wet distributor cap but not so hot for moving parts. It's based on fish oil if I remember right. So it does not have the tacky quality that would attract and hold dirt in a filter. Too thin and not the traits needed for filter prep. Now ya need to clean a wet or dirty connection, there ya go.
wrenchrob Posted May 2, 2013 #6 Posted May 2, 2013 I use to use 2 stroke oil in my motocross ad 4 wheeler air filters.
Miles Posted May 2, 2013 #7 Posted May 2, 2013 Brian, oh my gawd...Brian...here we go again. Last time I helped you work on the '89 Venture, you did not have a can of WD-40 in sight, and now you want to use a relative of that on a K&N air filter ??? What is WD10/40 anyway, BRIAN ????????? It is called...WD-40...not WD10/40. Geez, we can't leave you alone for 10 minutes without something weird happening in Buckley. Okay, to answer your question...if you do not have a can of K&N air filter recharger spray handy...which I do have...then you can use Marvel Mystery Oil...and they do make it in a spray, just for YOU. Love ya, brother.
GolfVenture Posted May 2, 2013 Author #8 Posted May 2, 2013 Miles..Not a dull moment when I'm around..
Drreb Posted May 2, 2013 #9 Posted May 2, 2013 I use the K&N kit. I figure if you spend a bunch for the filters use their stuff and you cannot go wrong. Just saying.
GolfVenture Posted May 2, 2013 Author #10 Posted May 2, 2013 I use the K&N kit. I figure if you spend a bunch for the filters use their stuff and you cannot go wrong. Just saying. Yep, I called O'Reilys and they have the K&N spray kit.
Peder_y2k Posted May 2, 2013 #12 Posted May 2, 2013 Mazola cooking oil works very well too .... Now that's a good one..........never thought of veggy oil, but it would work well and also make the filter more easily washed with lesser solvents/surfactants. Plenty of it in my kitchen cupboards. Maybe K&N oil is veggy...... Learn something new here ever day.... -Pete, in Tacoma WA USA '83,88
Yamamike Posted May 2, 2013 #13 Posted May 2, 2013 WD-40 was designed for more for water dispersion than lubrication. Works great for drying out a wet distributor cap but not so hot for moving parts. It's based on fish oil if I remember right. So it does not have the tacky quality that would attract and hold dirt in a filter. Too thin and not the traits needed for filter prep. Now ya need to clean a wet or dirty connection, there ya go. Plus it dries out pretty quickly:2cents:
Yamamike Posted May 2, 2013 #14 Posted May 2, 2013 Peder...veggie oil might work perfectly but when it goes rancid...yuk! Just sayin!
SilvrT Posted May 2, 2013 #15 Posted May 2, 2013 Peder...veggie oil might work perfectly but when it goes rancid...yuk! Just sayin! Now who goes around smelling their air filter ...
