gibvel Posted June 23, 2010 Share #1 Posted June 23, 2010 So, What was the verdict on your valve shims? How many needed to be adjusted and were they tight or loose? Do you notice a difference in the way it runs, if so, what difference? Link to comment Share on other sites More sharing options...
BradT Posted June 23, 2010 Share #2 Posted June 23, 2010 So, What was the verdict on your valve shims? How many needed to be adjusted and were they tight or loose? Do you notice a difference in the way it runs, if so, what difference? Ask Swifty, if there is any improvement, he most likely rode it further and harder than Don since it was done. Brad Link to comment Share on other sites More sharing options...
gibvel Posted June 23, 2010 Author Share #3 Posted June 23, 2010 But then Swifty wouldn't have any frame of reference for the before, now would he? Last I knew it was iffy whether he'd still be on the site anymore. Link to comment Share on other sites More sharing options...
V7Goose Posted June 23, 2010 Share #4 Posted June 23, 2010 Don's bike had only about 30,000 miles on it, so it was basically just due for the first valve check. All valves were within spec, with one MINOR exception (and not truly an exception). A single exhaust valve was right at max clearance. We did have a shim that would pull that clearance into the middle of the spec so we changed it, but technically, it was OK just as it was. Goose Link to comment Share on other sites More sharing options...
Freebird Posted June 23, 2010 Share #5 Posted June 23, 2010 Kent answered the technical part so I'll just say that no, I didn't notice any difference in the way it runs. I wouldn't expect to though because like he said, all were technically within spec. There is a real peace of mind factor though in knowing that they are OK. It was worth doing and very good training. It is a good sized job and I would dread doing it again but am confident that I could do so. Link to comment Share on other sites More sharing options...
Kirby Posted June 23, 2010 Share #6 Posted June 23, 2010 Now if we could just find that flat washer!!!! Link to comment Share on other sites More sharing options...
