Steve S Posted June 13, 2009 Share #1 Posted June 13, 2009 I do believe I am having the dreaded ignition switch failure and I would love some help with the diagnosis. Twice the bike has started, but the instrument panel has remained blank. This corrected itself when I turned the switch off, then back on. Often now it will reset my trip odometers to zero and the clock to 1:00 when I turn the switch off. I have reset the clock 3 times in 2 days so this is more than just a one time occurence. Is this some of the symptons of switch failure and is there an aftermarket switch available for the 2nd Gen? Many thanks to those that respond and help out. :bowdown: Link to comment Share on other sites More sharing options...
eusa1 Posted June 13, 2009 Share #2 Posted June 13, 2009 yes this is the early stages of ignition switch failure. easy to swap the key tumbler so that you don't have to have 2 keys. mike Link to comment Share on other sites More sharing options...
Sylvester Posted June 13, 2009 Share #3 Posted June 13, 2009 I am assuming (from the majority of past posts) that you have pass lights on your ride. If so you need to put them on a relay. If not you have a factory defect. Nothing else I have ever heard of trashes the ingnition switch. Unless you are running multiple electrical powers off you switch. Link to comment Share on other sites More sharing options...
1BigDog Posted June 14, 2009 Share #4 Posted June 14, 2009 If you need a new switch you can get it from here for about 125.00. Dealer msrp is 196.00. http://www.partshark.com/fiche_select.asp When changing the switch, make sure you have a dremel with a good cutting wheel to cut a slot in those security bolts. Also a good impact driver will be needed. Link to comment Share on other sites More sharing options...
GeorgeS Posted June 14, 2009 Share #5 Posted June 14, 2009 I might be wrong. But seem to remember sombody makeing a posting, that he removed the switch, dissassembled the switch, and was able to repair it. ??? But don't remember who, but as I recall it was about 6 months ago Its simply one bad contact in the unit. There is also a posting somplace as to Installing a hidden toggle switch, to bypass the On-Off contacts. Not that hard to do. Link to comment Share on other sites More sharing options...
BradT Posted June 14, 2009 Share #6 Posted June 14, 2009 I might be wrong. But seem to remember sombody makeing a posting, that he removed the switch, dissassembled the switch, and was able to repair it. This one ? http://www.venturerider.org/forum/showthread.php?t=34957 Brad Link to comment Share on other sites More sharing options...
Steve S Posted June 15, 2009 Author Share #7 Posted June 15, 2009 I am assuming (from the majority of past posts) that you have pass lights on your ride. If so you need to put them on a relay. If not you have a factory defect. Nothing else I have ever heard of trashes the ingnition switch. Unless you are running multiple electrical powers off you switch. Thanks for the tip Sylvester. I put anything that draws any kind of amprage on it's own relay when I install it hoping to avoid the switch problem. (I learned that years ago when working on DC systems with my brother-in-law.) I will pull the switch and repair it if possible, then put the entire system on a 50 amp relay. Hopefully this will prevent any future problems with the switch. Link to comment Share on other sites More sharing options...
