Treetall Posted May 22, 2019 Share #1 Posted May 22, 2019 So, new bike to me for a few months. I have a brake grinding noise on the front, only when I am almost completely stopped. It's fine at higher speeds. I pulled all the pads and they are like new...lots of meat. I checked the rotors (both front) and no grooves etc. I don't have a jack yet so can't lift the front end to see if the rotors are straight... what gives? Dirty? Out of true rotors? Need new pads? these defective? Thanks guys! Patrick Link to comment Share on other sites More sharing options...
Marcarl Posted May 22, 2019 Share #2 Posted May 22, 2019 I don't know whether you done this or not, but try to move the bike under power and then play with the front brake to see if you can better pinpoint the sound, it could be coming from elsewhere. You might even try to start at the top of an incline so you can shut the motor off to help locate it. More often than not the rear tends to make more sound issues than the front. And make sure the radio and such are completely turned off, completely turned off and helmet unplugged. Link to comment Share on other sites More sharing options...
M61A1MECH Posted May 22, 2019 Share #3 Posted May 22, 2019 The brake pads should have anti vibration shims or plates installed make sure they are there, if they are try getting some of that red spray on brake quiet stuff and treat the inside of the shim plates and the back of the pads. Link to comment Share on other sites More sharing options...
Condor Posted May 22, 2019 Share #4 Posted May 22, 2019 I'm thinking it might not be the brakes but, worn axle bearings.... Had that problem on the '83 and replaced the bearings. Solved the 'brake' noise... :-) Link to comment Share on other sites More sharing options...
bongobobny Posted May 22, 2019 Share #5 Posted May 22, 2019 Yup, that was going to be my suggestion, wheel bearings! Try to jack the bike up so the front wheel is off the ground and spin the wheel and apply the brakes to try to duplicate the sound. I'm betting you won't be able to duplicate it if the bearings are bad as there needs to be a load on the tire to make them grind... Link to comment Share on other sites More sharing options...
Freebird Posted May 22, 2019 Share #6 Posted May 22, 2019 All good suggestions but don't overthink it just yet. It is not at all uncommon on the RSV to get some a noise with the front brakes. Some brands of pads are worse than others. A lot of people have removed the pads and just slightly chamfered the leading edge of the pads and that successfully eliminated the noise. Link to comment Share on other sites More sharing options...
Treetall Posted May 24, 2019 Author Share #7 Posted May 24, 2019 Thanks for all the suggestions guys, I drove it in the rain today and with the liquid conditions there was no noise so I think I can rule out the front bearing. I think I am just getting brake pad chattering. So I'll look for some brake pad stay liquid and see if that helps... Patrick:canada: Link to comment Share on other sites More sharing options...
